Old 03-11-2020, 01:17 PM   #1
M2M
M2M's Avatar
Question Tudor seat pivot pin
The Tudor seat pivot pins the suppliers sell are not original, the are drilled for a cotter pin, see below image.
I have original pins but I'm missing the fasteners; where can I buy fasteners that work and are easy to install and remove? They don't have to be exact copies of originals...I just don't like cotter pins for this, plus the original pins don't have holes.
M2M is offline   Reply With Quote
Old 03-11-2020, 03:22 PM   #2
wmws
Default Re: Tudor seat pivot pin
My pivot pins have holes and cotter pins. They sure look original to me but I'm no expert. If the originals had no holes how are they kept in place?
wmws is offline   Reply With Quote
Old 03-11-2020, 04:11 PM   #3
Tacoma Bob
Tacoma Bob's Avatar
You might try Au-ve-co fasteners. The ones you speak of were common up until the 80s plus or minus.
Tacoma Bob is offline   Reply With Quote
Old 03-11-2020, 04:12 PM   #4
Mulletwagon
Mulletwagon's Avatar
Of the four pins on my Tudor, three are repops and use cotter pins whie the fourth is original and uses an "E" clip.
Mulletwagon is offline   Reply With Quote
Old 03-11-2020, 06:21 PM   #5
Bruce_MO
I had to lengthen my drilled ones by welding, then cutting off and using a lathe to turn the groove for a snap ring and beveled the end a bit. Then I simply wrapped a nail around them to get the ID close to the groove, and cut off the nail to fit. Squeezed with pliers to add a bit of tension. I don’t think it needs to have much spring tension to stay in the groove. Hope that makes sense. So yeah it’s a cosmetic thing
Bruce_MO is offline   Reply With Quote
Old 03-13-2020, 12:31 PM   #6
M2M
M2M's Avatar
Fastenal seems to have some possible solutions:
https://www.fastenal.com/product/fas...useData&view=1
https://www.fastenal.com/product/fas...sExpanded=true
Old 03-13-2020, 02:08 PM   #7
31Tudor
31Tudor's Avatar
This is what original pins and clips look like
31Tudor is offline   Reply With Quote
Old 03-13-2020, 03:35 PM   #8
jak
The problem is not finding the correct pins, but rather the wire form circle clips. They tend to distort when removed.
jak is offline   Reply With Quote
Old 04-28-2020, 04:42 PM   #9
M2M
M2M's Avatar
I think I'll buy the supplier's non-original cotter pin setup...it's not fun trying to remove and install E clips.
Old 04-28-2020, 06:51 PM   #10
CWPASADENA
CWPASADENA's Avatar
I am using "hair pin" spring clips instead of cotter pins or the "C" type wire retainers.
This is not original but I can pull the hair pins and remove the pivot pins and slide the seat to the rear get the seats out of the way when working in the area under the floor boards.
Actually, instead of using the stock length pivot pin, I made some longer ones with a rounded point that makes it very easy to re-install. I drilled the "cotter pin hole" in the same relative place as the shorter pivot pins.
This makes life a lot simpler.
Chris W.
CWPASADENA is offline   Reply With Quote
Old 02-03-2024, 09:35 AM   #11
benbuilder
Are the original pins shown in Post #7 available yet, I cannot find them
Thanks
benbuilder is offline   Reply With Quote
Old 02-03-2024, 12:44 PM   #12
katy
katy's Avatar
The original type clips shouldn't be hard to make, find a coil spring the proper size and cut it w/a disk grinder.
Old 02-04-2024, 11:10 PM   #13
CWPASADENA
CWPASADENA's Avatar
I use a clevis pin with a "hair pin" cotter pin to keep it in place. It is very easy to pull the hair pin and remove the clevis pin and slide the seats back onto the rear floor. This is especially handy when removing the floorboards to change the battery or do other maintenance in this area.
Chris W.
Old 02-04-2024, 11:53 PM   #14
Chris Haynes
Chris Haynes's Avatar
If someone with a lathe can repop some of those pins I'll buy four of them.
1921 Runabout
1930 Tudor
Early 1930 AA
Speed costs money. How fast do you want to go?
Chris Haynes is offline   Reply With Quote
Old 02-05-2024, 01:18 AM   #15
dave in australia
My Tudor is far from concourse, so I just used a bolt and nyloc. The shank of the bolt is long enough to go through both sides of the floor mount, and I have cut the length of the threads so I don't have to turn the nut heaps to fit. But removing seats is not a common thing for me, so the bolt and nut works well.
dave in australia is offline   Reply With Quote
Old 02-05-2024, 12:44 PM   #16
ldreeg
ldreeg's Avatar
For sale on eBay now with original clips:
eBay item number:204642107009
or
https://www.ebay.com/itm/204642107009?
Seem like a fair price for originals as they are unobtainable.
They are a pain to install the clips.
ldreeg is offline   Reply With Quote
Old 02-05-2024, 02:12 PM   #17
Gene F
Gene F's Avatar
Shoot I have bolts through mine, with the nuts that have that little nylon locking ring. You kinda have to be looking for them, and no one has even mentioned them to me. I'm a tall guy (38" inseam is the shortest I can wear) so I have the offset seat stands too.
I always thought a thin flat washer would do those pins a world of good.
Gene F is offline   Reply With Quote
Old 02-05-2024, 03:53 PM   #18
Karl Wescott
Karl Wescott's Avatar
These clips:
https://www.mcmaster.com/products/c-...taining-rings/
Karl Wescott is offline   Reply With Quote
Old 02-05-2024, 04:34 PM   #19
jak
Originally Posted by Karl Wescott View Post
I believe the original clips were round steel these look to be flat.
Old 02-06-2024, 11:59 AM   #20
katy
katy's Avatar
Shouldn't be hard to make, IF one knows the proper material and the proper dimensions.
