Old 03-07-2020, 09:49 PM   #1
diyforever
Unhappy Does tranny move forward during engine removal?
While removing engine, forgot the two lower bell housing bolts. Grrrr... Once bolts removed, engine came out. Removed bell housing to rebuild clutch and pedal shafts.
Installed rebuilt bellhousing. BUT i noticed now that brake pedal to cross shaft brake rod is now about ½ inch to short.
The rod won't reach the pedal. Is it possible the tranny moved forward when I was pulling/yanking the engine out?
If so, any tricks to slide it back...I hope!
diyforever is offline   Reply With Quote
