Old 02-26-2020, 07:39 AM   #1
rockfla
rockfla's Avatar
Default What's your "Go To" for a hard head?
So what is your "Go To" method for removing a "hard head"? Stud motor (not bolts) in particular......and do you find the right harder to remove than the left? Mine is "loose" in the sense of "off the deck" but will not budge beyond that. AND the more I force the back of the head the "more" the front comes off!!! It's so close BUT yet so far away.
File Type: jpg DB65D7D8-F9C1-4E93-81A5-20858777331E.jpg (53.1 KB, 97 views)
File Type: jpg 335C92F3-BDFD-494B-BBB1-EC4D57652DDF.jpg (45.9 KB, 96 views)
File Type: jpg 1F5CF1BB-AB15-4DA1-94AB-D67E1AF315E7.jpg (47.2 KB, 93 views)
Old 02-26-2020, 08:28 AM   #2
David J
David J's Avatar
Default Re: What's your "Go To" for a hard head?
33-34 Aluminum heads can be real stinkers about this . Yours is moving so tap it down and spray the studs with PB or whatever snake oil you prefer . Probably some buildup in the holes in the head binding on the threads .
David J is offline   Reply With Quote
Old 02-26-2020, 08:31 AM   #3
rockfla
rockfla's Avatar
Three days of WD-40, PB Blaster & LPS 1.
Old 02-26-2020, 08:43 AM   #4
David J
David J's Avatar
So much for the easy fix . Maybe a couple shims in the center and rock it front-back ? Finesse time ?
Old 02-26-2020, 08:55 AM   #5
JWL
I have a couple "T" handles I can screw into the sparkplug holes which can give extra pulling power. Usually if I can get some teeter-totter action on the head it will come off.
JWL is offline   Reply With Quote
Old 02-26-2020, 09:31 AM   #6
flatheadmurre
flatheadmurre's Avatar
I cheated a notch more...one slidehammer in each outer sparkplug hole.
Slidehammers lets you both pull and push the head back down....and some rustpenetrant of choice.
Old 02-26-2020, 09:38 AM   #7
oldford2
oldford2's Avatar
I made this lifter from old spark plugs. Helps to wiggle them but be gentle so you don't damage the threads.
Same as JWL's
oldford2 is offline   Reply With Quote
Old 02-26-2020, 09:42 AM   #8
Fordestes
Since you can pull it up a small amount try using wood pieces under the ends ,sides ,top and bottom of the heads , pry up alternately as in a back and forth rocking motion, wood will not damage the metal and act as leverage , a rubber mallet and with the snake oil on the studs as you are already using. and a little patience.
Fordestes is offline   Reply With Quote
Old 02-26-2020, 09:46 AM   #9
35fordtn
35fordtn's Avatar
I have used hooks welded to the base of a spark plug and used a slide hammer on the hooks..
The local flathead builder here uses air wedges (never tried it myself)
https://www.grainger.com/product/453...g!572999310232!
35fordtn is offline   Reply With Quote
Old 02-26-2020, 10:01 AM   #10
rockfla
rockfla's Avatar
There is NO "loose" what so ever in this head.....NONE......what "progress" you see pictured has come with "Extreme" Effort over two days....the front half "somewhat" easier than the back. AND when I say "Extreme" I am surprised as some point I haven't cracked the head. I am afraid, at this point....any negative travel (back down) will result in the same amount of effort required to get "Back" to where I am at now. I have once tried getting the head "as level" as I could BUT "any" effort to move it at that point was futile!!! What is puzzling to me is (and can be seen in my pictures) IS there in NO force applied on the front half of the head......all movement "there" has been achieved AS I have put force on and moved the back of the head??? The slide hammer suggestions are in my thoughts at this point but still open to ANY other ideas.
Old 02-26-2020, 10:01 AM   #11
Tim Ayers
Interesting. I've seen those wedges at Home Depot in the tool isle.
Old 02-26-2020, 10:01 AM   #12
Tim Ayers
Have you thought about making some wooden wedges to tap under the head?
Old 02-26-2020, 10:13 AM   #13
JSeery
JSeery's Avatar
Like this (see original post).
File Type: jpg DB65D7D8-F9C1-4E93-81A5-20858777331E.jpg (53.1 KB, 61 views)
File Type: jpg 335C92F3-BDFD-494B-BBB1-EC4D57652DDF.jpg (45.9 KB, 58 views)
Old 02-26-2020, 10:30 AM   #14
Tim Ayers
Haha. Hiding in plain sight
Old 02-26-2020, 10:34 AM   #15
flatheadmurre
The thing is not to put a crazy amount of force on it cause whatever is binding between studs and heads will come to a point and stopp...no matter the amount of force.
Wiggle them and the crud stuck in there will come out one tiny piece each cycle...not the best meditation but it works.
Old 02-26-2020, 10:35 AM   #16
rockfla
rockfla's Avatar
Not only yes BUT it is at the point that ANY more force applied to them is "peeling" the wood back!!!!
Old 02-26-2020, 11:09 AM   #17
Tim Ayers
Hmmm. If you have access to a torch, heat the head side around the stud holes to see if they'll enlarge enough to get past the studs.
Old 02-26-2020, 11:36 AM   #18
deuce_roadster
deuce_roadster's Avatar
I have a special very THIN hole saw like tool that just fits over the stud that goes down and cuts the aluminum oxidation that is causing the problem. This tool is made to be used by hand I think. I have never had to use it but understand how it works. The metal is about the thickness of a razor blade. Later today I will post a picture of it in my MISC album.
Old 02-26-2020, 11:50 AM   #19
40 Deluxe
Don't think these heads are aluminum.
Old 02-26-2020, 12:10 PM   #20
deuce_roadster
True, but it might work, the issue is the same. Pictures posted in MISC album. You would certainly have to go slow.
