#1 |
Guten Tag!
I have a problem with the light switch. It does not click into place properly. The parking light only works if I hold the steering wheel lever left against it. I used the copper spacer at the top. The compression spring below is new. The light switch is not worn out, it was replaced by the previous owner. Does somebody has any idea?
Beste Gruesse aus Deutschland, Werner Ford Model A, Roadster, 1928 Citroen 11 CV, 1947 Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version |
