#1 |
![]() City:
Portland
State:
OR
Price:
1000
This is a complete, drum to drum front end for 1932 Ford. Correct "heavy" axle.
Completely stock, mechanical brakes. Comes complete with: -axle -brakes -steering -pitman arm -wishbones -spring Axle is not totally perfect, it has wear from spring shackles as most do. Bones and axle are reasonably straight. Not run-a-laser-down-it-straight, but reasonable. Correct and are very workable/usable. Wishbone ball mount worn. Repairable, or good option for split bones. Good old well used front end that has a ton of desirable parts on it. Location is near Portland, Oregon. I will hold (with payment) if you are planning to come to the Portland Swap Meet. Otherwise local pick up, or I will put it on a pallet and drop it off at my local Fastenal store. I don't know what that would cost, you will have to call Fastenal to inquire.
ironandsteele.com
#2 |
ironandsteele.com
