Old 01-16-2020, 10:41 AM   #1
Biggles
Biggles's Avatar
Default Where has billben/flathead gone
The flathead tech site at
http://www.btc-bci.com/~billben/flathead.htm
seems to have shut down - or has it just been moved?
Biggles is offline   Reply With Quote
Old 01-16-2020, 10:49 AM   #2
JSeery
JSeery's Avatar
Default Re: Where has billben/flathead gone
That does not appear to be a valid URL.
Old 01-16-2020, 10:55 AM   #3
19Fordy
19Fordy's Avatar
The bill/ben site was priceless. Hope it get's found.
Here's another flat head support site that I just found.
http://myflatheadford.com/
Old 01-16-2020, 12:36 PM   #4
JWL
My good friend who established that site passed away a couple of years ago. Bill Bentley helped me get my first order of books printed and was someone I wanted to be like when I grow up.
There was a Flathead lover from CA who kept the site going for some time but I am not aware of the present circumstances.
JWL
JWL is offline   Reply With Quote
Old 01-16-2020, 12:39 PM   #5
Ross F-1
Ross F-1's Avatar
Bill Bentley passed about 5 - 6 yrs ago. The site remained active for maybe a year, but folded.
I believe it was Carl in Roseville CA who kept the site going
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 01-16-2020, 01:03 PM   #6
V8COOPMAN
V8COOPMAN's Avatar
Click on this link! DD
Techno Source for the 1932 thru 1953 Flathead Ford
Click Links Below __
T5 W/TORQUE TUBE
Old 01-16-2020, 01:50 PM   #7
JSeery
JSeery's Avatar
Originally Posted by V8COOPMAN View Post
I was aware of that site, didn't realize it was related to the site in question.
Old 01-16-2020, 02:00 PM   #8
V8COOPMAN
V8COOPMAN's Avatar
When you click on it, it says something like "http//billben/flathead" in the header up at the very top. They're not one and the same? DD
T5 W/TORQUE TUBE
Old 01-16-2020, 02:12 PM   #9
Biggles
Biggles's Avatar
Many thanks DD.
May we be assured of continuation?
Old 01-16-2020, 02:20 PM   #10
V8COOPMAN
V8COOPMAN's Avatar
Originally Posted by Biggles View Post
Many thanks DD.
Man, I ain't got a clue. I only lucked-out piddling around trying to find a way to fetch it. Time will tell! DD
T5 W/TORQUE TUBE
Old 01-16-2020, 03:52 PM   #11
Mart
Mart's Avatar
Many thanks DD.
Hi Neil.
Well, that is a snapshot capture of the site at some time in the past. It has already gone and you can't guarantee all the links will work.
If there are specific articles or posts you were looking for if you can find them you might want to copy them to your local machine.
All the best.
Mart.
Old 01-16-2020, 03:57 PM   #12
tubman
tubman's Avatar
Check out the website it resides on : "web.archive.org". Also, "~billben/flathead.htm" is an archaic way to associate a directory of files to a website back when individual websites were too expensive or too difficult to set up. It looks to me that someone had the foresight to move that information to "cloud" storage where it can reside forever, rather than leaving it on an old website that would eventually disappear. Kudos to them!
tubman is online now   Reply With Quote
Old 01-16-2020, 05:55 PM   #13
JSeery
JSeery's Avatar
This is interesting. I used the site that proceeded this one and then later in time this one. If I remember correctly there was a notice posted several years ago about some of the information going away and I downloaded a lot of it at that time. Was totally unaware of the billben connection, or didn't recognize the site I was on!!
Old 01-16-2020, 06:23 PM   #14
1936 ford pickup
[QUOTE=V8COOPMAN;1841994]Click on this link! DD
HELLO and THANK YOU for this information....WOW....I clicked on the above link and then clicked on the link FLATHEAD TOWING and read the information. Never even considered the possible issue at hand with flat towing. Has anyone else flat towed a vehicle with the closed/solid drive line with manual transmission. I have a car-dolly and was planning on towing my '36 Ford pickup with closed/solid drive line with 3 speed manual transmission to (approximately 3-4 hours drive) long distance car shows. Any thoughts back on this would greatly be appreciated. I might add that my '36 Ford pickup is pretty much stock but has the MITCHELL 36% Overdrive installed.
THANK YOU....
Thank you,
Bruce in California.
1936 ford pickup is offline   Reply With Quote
Old 01-16-2020, 06:36 PM   #15
19Fordy
19Fordy's Avatar
In 1967 I flat towed my 40 Ford coupe 300 miles behind my 57 Pontiac from Poughkeepsie, NY to Wellfleet, MA. Used a tow bar bolted to the 40 frame rails on the front. Did not disconnect the drive shaft. Left trans in neutral. Didn't hurt anything. But, you can't back up.
Old 01-16-2020, 06:44 PM   #16
Brian
Brian's Avatar
If you're real worried, just fill the gearbox to the top.
Unfortunately, two half wits don't make a whole wit!
Brian is online now   Reply With Quote
Old 01-16-2020, 06:47 PM   #17
Mart
Mart's Avatar
Re flat towing: If you prop the clutch pedal down it allows the natural drag in the gears to keep things turning and circulate oil around the box.
Mart.
Old 01-16-2020, 10:33 PM   #18
Ol' Ron
Ol' Ron's Avatar
Bill was a good friend of mine, he helped me quite abit. I miss hinm
Ol' Ron
PS. those ports remind me of the way we did them back in the day. I don't quite do them that way anymore. Like everything else the system of porting evolves over the years, snd we keep improving it as the years go by. However, those ports work quite well.
Old 01-17-2020, 03:10 AM   #19
Alaska Jim
Alaska Jim's Avatar
Bill Bentleys site and the Techno site were related. all the info on the techno site came from members contributions from Bill's site. when Bill Passed away and Carl took over I inquired if there was a way for some one to download all the info on the techno site onto a cd/dvd or flash drive. and make it available for sale at a reasonable cost to help keep the site going, but got no response. I mentioned at the time that If I had the knowledge, that I would do it. I was not very computer/tech literate at the time , and still am not. I am lucky I can turn the computer on. There is a lot of info there on the techno site . I printed a lot of it out, but I doubt I got it all.
Alaska Jim is offline   Reply With Quote
Old 01-17-2020, 09:23 AM   #20
JM 35 Sedan
JM 35 Sedan's Avatar
That was the first Early Ford Flathead V-8 website that I tuned into, probably in the mid to late 90's. I felt very fortunate to have found that for all the friends and great information found there. Later, probably around 2000, I met Ol' Ron at the York, Pa, NSRA Street Rod Nationals, bought his book, and followed his advice to check out the Fordbarn website....been here ever since I did that :-)
John
