01-15-2020, 07:12 PM | #1 |
fan belt?
what is the 5/8" belt length for a 8ba for typical crank- water pumps-generator arrangement ??
01-15-2020, 09:19 PM | #2 |
Re: fan belt?
You can check Rock Auto to get a brand and part number, then go to the manufacturer's site.
01-15-2020, 09:23 PM | #3 |
Re: fan belt?
Such as: Gates TR0544........54.73" outside circumference.
01-15-2020, 09:25 PM | #4 |
Re: fan belt?
A decent way to quick check a belt size is with a piece of string. Mark were they meet and measure it. Works for anything with a belt.
01-15-2020, 10:57 PM | #5 |
Re: fan belt?
I found that the Rock Auto Website gives the length of the fan belts. I think the truck belts were 5/8" wide.
Plug in the numbers for your vehicle and see what you can find. https://www.rockauto.com/en/catalog/...rive,belt,8900 |
01-15-2020, 11:09 PM | #6 |
Re: fan belt?
01-16-2020, 02:13 AM | #7 |
Re: fan belt?
Or just walk into the local farm supply and get a B-52 belt.
It depends a little on what pulley you have on the generator a low rev high charger generator has a smaller diameter and there is a bigger then normal one to...but usually B-52 fits nicely. Trying to order one on model here would be an adventure...lol |
01-16-2020, 10:14 AM | #8 |
Re: fan belt?
I'm using Gates BX52 and Gates BX35 on my 8BA
01-16-2020, 12:40 PM | #9 |
Re: fan belt?
01-16-2020, 04:57 PM | #10 |
Re: fan belt?
Hey guys ! Any of you ever use a (single) 1/2 belt w/the 5/8 pullys on the crank , waterpumps , & alternator ? Just wondering if it would work ok ....
01-16-2020, 05:43 PM | #11 |
Re: fan belt?
I believe a 1/2” belt in the 5/8 pulleys would work, but NOT ok. A belt should bite the pulley with the sides of the belt. The belt should not be at the bottom of the pulley, and I think that’s what you would have with a 1/2” belt.
01-16-2020, 06:29 PM | #12 |
Re: fan belt?
Jay - Yeah , that males sense . I just thought it might make mine less " squeaky" . Thanks for the quick answer ! - F F
01-17-2020, 10:49 AM | #13 |
Re: fan belt?
I have my 48 crankshaft pulley off and took a narrow belt, wrapped around it and there is about an 1/8 inch off the bottom of the pulley. I am looking at driving a type ll power steering pump off the front pulley. I cant find a narrow belt pulley for the front or a wide belt pulley for the type ll. Any ideas?
01-17-2020, 11:26 AM | #14 |
Re: fan belt?
Problem is that a narrower belt can´t handle the same amount of power and not wear out faster.
And you need enought length of the belt to make contact with the pulley. I´ve seen setups where you ad PS and AC on top which makes the belt barely touch the waterpump...not the best solution. Making a custom widebelt pulley for the PS pump is one way of solving it... |
01-18-2020, 10:00 AM | #15 |
Re: fan belt?
Thanks for the input, I thought that would be the best way to go.
01-18-2020, 02:35 PM | #16 |
Re: fan belt?
01-19-2020, 02:35 PM | #17 |
Re: fan belt?
Nice to see that a36bonanza provided the answer.
