Old 01-15-2020, 11:15 AM   #1
pinball73
Default steering sector
Well I rebuilt my seven tooth steering sector, all new parts & bearings & i still ended up with about three inches of free play in the center! as best as I can figure there is no way to get rid of it without going back with original Henry gears & maybe that might not fix it. I am in the process of building a two tooth sector & I would like to use my steering wheal! the only problem is my steering wheal is splined & the two tooth steering shaft is keyed. is there a way around this problem other than buying a new steering wheal?
pinball73 is offline   Reply With Quote
