Old 01-07-2020, 05:41 PM   #1
Ziggster
Default Can I/should I attempt to rebuild my helmet dizzy?
I will be using a helmet dizzy on my C59/69A flathead. With all the recent threads on associated machines to adjust points/dwell etc. I'm even more confused if this is something I should even attempt. I feel I could complete the rebuild without issue, but the issue of properly adjusting it bothers me especially on a freshly rebuilt engine. Engine is stk heads, intake, carb, crank, stk pistons (0.060"), with an Isky 1007B profile cam. What say the experts?
Ziggster is offline   Reply With Quote
Old 01-07-2020, 05:49 PM   #2
Terry,OH
Terry,OH's Avatar
Default Re: Can I/should I attempt to rebuild my helmet dizzy?
Sure go ahead. What year helmet or are you going to use a crab? If you don't like to get your hands dirty you can send it out, but you can learn a lot doing it yourself.
Old 01-07-2020, 05:51 PM   #3
35fordtn
35fordtn's Avatar
I think you surely can. Likely without a fixture and/or machine the dwell or timing will be off a smidge, but will still likely run just fine. We (refering mostly to myself) get way too technical on these old distributors and strive to make things perfect when in reality if the dwell or timing is off a degree or two it will still run just fine. At worse case scenario, rebuild it yourself completely (as in don't just sling points in it) and have someone with a timing fixture and sun machine set it up for you. The cost for that would be minimal
They are fun and incredibly easy to rebuild and you will enjoy it.
35fordtn is offline   Reply With Quote
Old 01-07-2020, 06:02 PM   #4
Tim Ayers
Great advice,
Old 01-07-2020, 06:07 PM   #5
cadillac512
cadillac512's Avatar
I agree. I went completely through mine on the original '41 Merc engine and it was not a big deal. Just be gentle and take your time with anything that's a bit stuck or corroded,clean it all up and lube it, adjust the points with a feeler gauge and reinstall it. Like Mike said above...easy to get too picky when it'll work great with careful work and normal tools.
Terry
p.s. Buy good parts!
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'30 Model A Speedster
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 01-07-2020, 06:19 PM   #6
Ziggster
Thanks for the advice and encouragement. Don't mind getting dirty, and my inquisitive engineer mind is a bit curious as to how this thing actually works.
Old 01-07-2020, 08:24 PM   #7
Ziggster
Here is a pic of my helmet dizzy. Coil hsg is cracked at one of the mounting screw ears. Appears someone added some sort of goop to seal it.
Old 01-07-2020, 08:25 PM   #8
Ziggster
There is a number "5" and what looks like an "S" cast or engraved in the rear plate.
Old 01-07-2020, 08:27 PM   #9
Ziggster
There is the number "3" also cast or engraved in the bottom of the hsg.
Old 01-08-2020, 08:01 AM   #10
Terry,OH
Terry,OH's Avatar
You have the 37-41 helmet distributor. I would suggest going to Skip Haney for a replacement coil. He rebuilds originals to better than original and also a new condenser tested by himself. Ford did not cast the body of the distributor but had about 3 different suppliers that for identification cast their Ford identification number in each. the numbers. All of the 37-41 distributors use the same settings and inter changeable internal and external parts. In 41 there was a change to the advance weights and advance plate allowing the advance to come in slightly sooner and slightly more about 2 degrees. The 41 advance plate is marked 11A-xxxx for the modified advance which is considered slightly better.
Old 01-08-2020, 08:32 AM   #11
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Yep do it yourself ike the others have stated.
Heres a Bubba video with some tips etc, if ya have a problem feel free to email ( I hate the phone) me or Mike .
And buy the Echlin CS47 point sets from NAPA..
https://aviondemand.wistia.com/medias/expa13egyr
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 01-08-2020, 02:55 PM   #12
Hoop
Hoop's Avatar
If you are even thinking about it, do it.
Use caution pulling the internals out of the housing. You may have to soak the insides with penetrating oil and even carefully warm up the housing with a propane torch. Be careful with hammers! Bubba has a long relationship with hammers ... he's not being as casual as it appears.
"Remember that when it comes to intelligence, half of all of us are below average."
Hoop is offline   Reply With Quote
Old 01-08-2020, 03:28 PM   #13
Ziggster
Thanks to everyone one for the advice and encouragement. I now know I made the right decision to use the helmet. I did some late night reading on sevetal threads on here, HAMB, and EFV-8 about the helmet, and it's history. It was fascinating reading, and it seems there was a bit of industrial intrigue behind the scenes with Ford, Mallory, and Zoerlein. How to I get in touch with Skip?
Old 01-08-2020, 03:32 PM   #14
petehoovie
petehoovie's Avatar
Old 01-08-2020, 04:01 PM   #15
35fordtn
35fordtn's Avatar
I like the helmet with 11a guts better than the infamous crab distributor. It performs essentially the exact same. Be sure you check the upper bushing they are commonly worn and there is a trick to removing it than allows you to remove it in less than 20 seconds
Old 01-08-2020, 04:07 PM   #16
FrankWest
FrankWest's Avatar
Go for it! You want to become a expert on your car. Do everything to learn except something that requires a 10 ton press, then send that out to be done. Ha Ha.
FrankWest is offline   Reply With Quote
Old 01-08-2020, 06:16 PM   #17
Ziggster
10 ton press? That's for kids. Lol...
Old 01-08-2020, 06:17 PM   #18
Ziggster
Thanks.
Old 01-08-2020, 08:12 PM   #19
Ziggster
I see mine has 68 stamped on the drive end. Checked my crab and couldn't see anything on the back of it.
Old 01-08-2020, 08:33 PM   #20
35fordtn
35fordtn's Avatar
The crab ones, are not stamped. But they are the same as a 11A helmet.. Converting your to a 11A is a easy and worthwhile task.
