#1 |
I'm trying to install the switch, and my problem is the shaft you tighten with the brass nuts isn't long enough, so how do you guys do it? Thank you. Don
#2 |
Where are you trying to install the switch??
Bob |
#3 |
I was trying to install it on the floor through the cross member that supports the front floor boards. just the 3/4 plywood is to thick.
#4 |
Those come with different length shanks,you need to buy the one that fits your application.
#5 |
Obviously I did't know that, thanks for the info I'll do some more research and see if I can get the right one. thanks again. Don
#6 |
#7 |
DBrer,
What model are you trying to install your switch in? I put one in my fordor (Town Sedan) and I put it in the seat riser right under the driver's seat. The metal was thin and the switch is readily accessible. I built a small wooden box under the seat to protect the back of the switch from anything stored under there. Just a thought. Marty |
#8 |
I'm trying to install the switch in a 29 Tudor sedan. I saw the panel in the fordor sedan and that would be perfect if I had the panel. Thank you. Don
#9 |
#10 |
I cut a round hole in the floor board, mounted the switch on the cross member supporting the front seat. The switch handle sits just below the floor surface allowing me to make a round sheet metal cover that swings over the hole. This way I can open and close it when I switch the unit on or off. This is on a 1930 Tudor.
#11 |
You could make a duplicate floorboard and save the one that came with the car if that is important.
#12 |
If you look in a Cole-Hersey catalog you will see lots of different options.They also make one with a short shank,with a long stem.That one you can mount behind or under something,with just the skinny shaft poking through a small hole.The one to stay away from are the plastic ones.They don't like a lot of hot amps running through them when a 6 volt starter is churning over.
#13 |
With the small amount thread you have on the switch you could mount it in the hole of the rear motor mount. You have to lift the hood to check oil anyway.
