12-12-2019, 08:44 AM | #1 |
Air Filter
Anybody make their own air cleaner for the zenith carb? I was looking at K&N too brain storm how to do it. Maybe PVC, Hose, clamps and clamped on filter.
12-12-2019, 10:02 AM | #2 |
Re: Air Filter
I guess you could make an air filter out of anything. But why bother. I have a K&N and it works fine out of the box.
12-12-2019, 10:32 AM | #3 |
Re: Air Filter
How about a picture and/or a part #.
12-12-2019, 10:51 AM | #4 |
Re: Air Filter
Here is a link to the Red Quail Early Ford Parts, I have made several purchases form them, nice products and good to deal with. Here is a link to their web page. They have an air cleaner for you "right handers" also
https://www.redquailearlyfordparts.com/ |
12-12-2019, 10:53 AM | #5 |
Re: Air Filter
I bought one from Red Quail and within about 25 miles it fell off and got lost.
12-12-2019, 12:24 PM | #6 |
Re: Air Filter
1924 Model T Coupe 1928 Model A Roadster 1930 Model A Town Sedan 1939 Deluxe Fordor 1945 pickup 1951 Custom convertible |
12-12-2019, 12:39 PM | #7 | |
Re: Air Filter
While mine has never fallen off I can imagine the engine pans would keep it from getting lost. Just sayin'. I have one from Snyder's, which I believe is the same one made by Red Quail.
The Master Cylinder Enjoying life at the beach in SoCal... Last edited by The Master Cylinder; 12-12-2019 at 12:50 PM. |
12-12-2019, 12:44 PM | #8 |
Re: Air Filter
12-12-2019, 01:10 PM | #9 |
Re: Air Filter
12-12-2019, 01:54 PM | #10 |
Re: Air Filter
Keep in mind that an updraft Zenith carburetor will leak fuel at some time and if you have a filter mounted to it, it may become saturated with fuel. If the engine should backfire on start up because the spark advance lever was left in the down position the filter material may light off.
Tom Endy Last edited by Tom Endy; 12-13-2019 at 12:04 PM. |
12-12-2019, 03:32 PM | #11 |
Re: Air Filter
I have one similar to the updraft red quail made from 2 copper pipe elbows and a nitrile rubber type sleeve to the carb with hose clamps. Hasn't fallen off yet. The filter is a K&N type 5" tall but have no part no. A 3" dia. x 5"h or greater tall filter usually won't restrict air flow like the Airmaze can.
12-12-2019, 03:44 PM | #12 |
Re: Air Filter
Here is a link to a post on KandN filter I fitted to my RHD
Model B carb. It works well, mixture is light tan on plugs with 1/4 turn open on GAV, carb is not balanced for vacuum. https://www.fordbarn.com/forum/showthread.php?t=209736 SAJ in NZ |
12-12-2019, 06:07 PM | #13 |
Re: Air Filter
I use the K&N Air Filter #5297. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Guess I'm lucky as my filter does not "become saturated with fuel". |
12-12-2019, 06:23 PM | #14 | |
Re: Air Filter
I have tried to put a B carburettor on an A engine but the steering column prevented it. Determined, I shortened the verticle tube of the inlet manifold and reattached the flange but with a bit of a twist so the intake cleared the steering box. That meant the choke rod wouldn't line up so I moved the knob to the left of the steering column and put a little universal joint in the choke rod just above the floor (I made my own steering column support bracket to accomodte it). That worked a treat. I can understand why the American vendors don't sell this sort of stuff for RHD cars because we have all found our own solutions and therefore don't need one of theirs.
12-13-2019, 05:25 AM | #15 |
Re: Air Filter
Interesting Synchro. My wife's Tudor with standard rear eng mount cleared the B carb by 3/16 inch, allowing the 24 gauge rolled airbox spigot to fit closely on the inlet stub with about 1/8 inch clearance to the 2 tooth steering tube. But my 1930 Roadster with 2 tooth box fitted and new FAM rubbers would not clear. I packed the RH bottom FAM rubber up by 5 mm twisting the motor slightly in the chassis I think from memory. It has rubber front mounts too and I think I packed the front RH one up too. I have worked on so many other cars for the club I cannot remember. Anyway this gave about 1/8 clearance to the steering tube. I suspect every car us slightly different which is why you could not fit a B carb to yours Arnold without the mods you did.
Since I manufacture fibreglass resins I suppose I should make some f glass ones as you suggest for the club. The steel intakes take me several hours to make and fit. SAJ in NZ |
12-13-2019, 06:50 AM | #16 |
Re: Air Filter
This is the K&N that I have. It measures 3-3/8 long. I have had it a while and don't remember where I bought it.
Red Quail. They have the best fuel filters I have ever tried. A little more expensive but they are great. They are longer than NAPA, Snyders, Brattons and the top gasket fits the top holes of the filter better than the others. Last edited by old31; 12-13-2019 at 07:15 AM. |
12-13-2019, 11:02 AM | #17 | |
Re: Air Filter
12-13-2019, 02:04 PM | #18 |
Re: Air Filter
This is the Hi-Boy filter on my '29 roadster. I used repop Model-A hose clamps painted flat black with brass screws on the filter. They make it more
"antiquey" looking to me. Bob-A |
12-13-2019, 03:53 PM | #19 |
Re: Air Filter
That Swan intake manifold is right purty . .
12-13-2019, 04:02 PM | #20 |
Re: Air Filter
My first thought on seeing that manifold was: Is the carburettor sitting higher? That might be a solution but then I saw that there is no provision for the distributor advance rod. That could probably be overcome so I ask: "Does the carburettor sit higher than with the original manifold?" I kinda doubt it or the GAV/choke rod wouldn't line up.
