Old 12-08-2019, 10:55 AM   #1
dudley32
dudley32's Avatar
Default 1933 Ford foot starter
Could someone tell me how the foot starter button attaches to the car? I have a '33 Ford sedan I'm putting together with a 59AB engine and a '50 Ford pickup transmission. Photo's would be nice...thanks
dudley32 is offline   Reply With Quote
Old 12-08-2019, 11:20 AM   #2
deuce lover
deuce lover's Avatar
Default Re: 1933 Ford foot starter
If you are using the original switch.That starter switch bolts to 2 lower bolts on the steering box ,then the rod that goes thru the floor threads into it.
File Type: jpg 33,34 Ford starter switch location.jpg (109.7 KB, 61 views)
deuce lover is offline   Reply With Quote
Old 12-08-2019, 11:38 AM   #3
dudley32
dudley32's Avatar
o.k.thanks...I thought it went over by the accelerator pedal and could not figure it out...appreciate that
Old 12-08-2019, 11:39 AM   #4
Bored&Stroked
Bored&Stroked's Avatar
Something to think about - depending on how "original looking" you want it to look like - is to add a modern Ford starter solenoid (12V, think 60's mustang) to handle the actual starter load and use the above starter switch to activate the solenoid. I've found this tends to make the stock starter type switch last a lot longer as it only has to activate the solenoid.
Obviously your main battery/starter cables have to be setup/routed differently (to go to the solenoid instead of the starter switch above). Just something to ponder if you're wiring the car from scratch . . .
Old 12-08-2019, 11:54 AM   #5
dudley32
dudley32's Avatar
and thanks again...
Old 12-08-2019, 06:35 PM   #6
koates
Nothing wrong with the original foot starter switch provided it is wired up with the correct heavy gauge battery cables. No need for a solenoid. It acts as a good anti theft device because no modern car thief would know how to start it. Regards, Kevin.
koates is offline   Reply With Quote
Old 12-09-2019, 11:51 AM   #7
whizzernick
whizzernick's Avatar
also useing 12 v puts a smaller amp draw on the sw. a good sw should last foever
whizzernick is offline   Reply With Quote
Old 12-09-2019, 11:58 AM   #8
Ken Arms
Ken Arms's Avatar
A good working e-brake is handy since your left foot will be running the starter and your right foot on the gas!
Ken Arms is offline   Reply With Quote
