Old 11-28-2019, 05:36 PM   #1
old31
Default Knocking at start up?
What would cause a knock at startup? The knock is only for about 20-30 seconds, then it stops.
After startup, it does not matter where the spark lever is positioned.
Old 11-28-2019, 05:58 PM   #2
George Miller
George Miller's Avatar
Default Re: Knocking at start up?
center main is one but it depends on the sound.
George Miller is offline   Reply With Quote
Old 11-28-2019, 06:25 PM   #3
Mulletwagon
Mulletwagon's Avatar
Maybe a sticking valve. Might try Marvel Mystery Oil first.
Mulletwagon is offline   Reply With Quote
Old 11-28-2019, 06:25 PM   #4
Mark in MT
Piston slap, until oil gets up into cylinder, and pistons warm up. If it is more noisy when cold than warm, this may be it.
Mark in MT
Always looking for another opportunity to be wrong.
Mark in MT is offline   Reply With Quote
Old 11-28-2019, 06:31 PM   #5
frank mcdaniels
frank mcdaniels's Avatar
Make a stethescope with a long rod of some kind and put it on the engine while it’s running. You will be amazed at what you hear going on in there. My roadster knocks to until it warms up. I’m sure it’s a main bearing I’ll have to address it sometime in the near future . Frank
frank mcdaniels is offline   Reply With Quote
Old 11-28-2019, 07:59 PM   #6
CWPASADENA
CWPASADENA's Avatar
If the main bearings are a little loose, all the oil in the valve chamber will leak out thru the mains when the car sets for a period of time. When you first start it, it takes a few seconds to pump oil back up into the valve chamber and gravity feed on down to the main bearings. This will result in a knocking sound for a few seconds.
This usually only happens with babbet bearings and not insert bearings.
This usually happens after the car sets overnight or longer and not after being shut off for just an hour or so.
10/40 or 20/50 oil may help.
I ran an engine for several years like this and it did not get any worse. I was too lazy to drop the pan and take up the bearings. Just run the engine slow and do not put any load on the engine until the oil gets pumped up.
Chris W.
CWPASADENA is offline   Reply With Quote
Old 11-28-2019, 08:28 PM   #7
Patrick L.
Patrick L.'s Avatar
I too would think its probably the center main. But a stethoscope could help pinpoint where the noise is coming from.
The lever should be up for starting and upon start up it should be pulled 1/2-3/4 way down.
Old 11-28-2019, 09:33 PM   #8
J Franklin
J Franklin's Avatar
Too much slop in the thrust bearing caused just that in an engine I had. Test this theory by not pressing the clutch before starting up the car next time.
Old 11-28-2019, 11:35 PM   #9
30 Closed Cab PU
I had something similar, only when cold, but gradually got worse over a couple of thousand miles. Ended up being a crack rod cap, Because I waited and then had the motor rebuilt, teh rebuilder had to bore the cylinders from .020 to .080 over due to wear issues caused by the cracked rod cap. So my advice is do not wait, find out what the problem is asap, am now a big believer in if there is an issue identify it sooner than later.
30 Closed Cab PU is offline   Reply With Quote
Old 11-29-2019, 04:54 AM   #10
old31
I always use MMO at every fill up.
Old 11-29-2019, 04:57 AM   #11
old31
OK, I will try this and report back.
Old 11-29-2019, 09:44 AM   #12
eagle
eagle's Avatar
I’d say pull the oil pan and look it over. For a quick test, buy a bottle of Slick 50 and put it in. I imagine I’ve just woke up the scoffers with that comment but if you have a worn engine it DEFINITELY will help. A Teflon film on the bearings will keep the squirrel rattlers quiet.
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool."
eagle is offline   Reply With Quote
Old 11-30-2019, 11:03 AM   #13
SSsssteamer
SSsssteamer's Avatar
I had an engine like that also that had the piston slap when it was first started cold. It had been re-ringed when it first should have been re-bored.
SSsssteamer is offline   Reply With Quote
Old 11-30-2019, 05:18 PM   #14
Brendan
Brendan's Avatar
i can measure my thrust with a tape measure and i have no knock
If it would have been a snake it would have bit ya!
i can't spell my way out of a paper bag!
Brendan is offline   Reply With Quote
Old 11-30-2019, 10:21 PM   #15
DBrer
I have a tendency to agree with some of the guys. To much main bearing clearance can cause noise until oil lubes the crank.
DBrer is offline   Reply With Quote
Old 12-01-2019, 10:41 AM   #16
old31
Follow up:
I started it up without pressing on the clutch, and there was no knocking at all.
Soooo, what does that tell you?
Old 12-04-2019, 09:09 AM   #17
old31
J. your theory shows it does not knock when the clutch is not depressed on startup.
So, how is this fixed? If it doesn't hurt anything I won't bother.
Old 12-04-2019, 09:25 AM   #18
Marshall V. Daut
Check your private messages on this website.
Marshall
Old 12-04-2019, 01:42 PM   #19
J Franklin
J Franklin's Avatar
Too much end play can cause the crank to be pushed forward and make the rods mis-align. Things tend to find centers after it gets running and oiled. Play in the thrust area can be measured and repaired.
Old 12-05-2019, 08:50 AM   #20
ryanheacox
ryanheacox's Avatar
On my old engine, pushing the clutch in before startup would result in a loud clunk. The thrust was very worn and the crank would move about 1/16"... knocked louder from the center main and disintegrating #4 rod bearing though.
ryanheacox is offline   Reply With Quote
