11-24-2019, 02:08 PM | #1 |
Ballast resistor question...(Bubba?)
My 36 was converted to 12 volts by the prev owner with a kit from vintage auto garage. Still running the ford dual point helmet dizzy w/remote mounted 12v coil and a ballast resistor. If I look on vintage auto garage's website now, they still sell these kits but I no longer see a ballast resistor. Can I assume if I run the 12 volt coil they now sell, it has an internal resistor? Reason I ask is, the ballast resistor on my firewall is looking suspect and I would either like to buy another for a replacement, OR, do away with it entirely.
The coil with their kit is this RUC15 (https://www.vintageautogarage.com/pr...ductcode=RUC15) which appears to have an internal resistor?
Regards, Todd 1936 FORD Tudor Slantback "cajunhotrodder" on instagram/youtube |
11-24-2019, 03:05 PM | #2 |
Re: Ballast resistor question...(Bubba?)
It says in the ad that no external resistor is required so it's ok to run as is.
11-24-2019, 03:12 PM | #3 |
Measure the resistance of the ignition coil you have...that will tell you if you need an external resistor or not.
And what value it will need to be... |
11-24-2019, 03:12 PM | #4 |
We now ship a internal resisted coil with our conversions , the ballast ( or lack there of) has been a huge problem for everyone involved. And still is for some makers of kits with no coil added to kit. |
