11-05-2019, 10:11 PM | #1 |
1947 convertible
Question:
New to the V8 world and have been enjoying my '47 convertible this summer. On a trip Sunday the car suddenly started running poorly, like someone turned a switch. I stopped and found a plug wire had popped off. Started driving again and it did the same thing but this time the plus wires were fine. I pulled all wires off and crimped them to tighten the fit on the plugs. The car ran well for another 20 mins and then it ran poorly and this time quit. Upon inspection I could find nothing wrong. It would turn over but and fired once but would not run. I live in Maine and the temps were in the 50s so do not expect vapor lock. Sediment bowl was full. I had it towed home. Haven't done anything else to determine cause but suspect it's electrical. Any suggestions on where to start looking? |
11-05-2019, 11:46 PM | #2 |
Re: 1947 convertible
coil, condenser, wires, fuel pump, fuel filter, pluged fuel cap, restricted fuel line, just a few possibilities.
11-06-2019, 05:28 AM | #3 |
Coil & condenser would be my starting point.
19 and 49 F1 - jes' like Henry II built 1946 Deluxe - as Henry built it |
11-06-2019, 07:22 AM | #4 |
Is it the original coil? Or has someone converted a it to a remote coil. Skip Haney rebuilds coils, search this forum for his info. Also Tubman on this forum sells condensors that should last you a long time.
11-06-2019, 09:01 AM | #5 |
As the other guys have said it's likely ignition. If it were mine, not knowing the past maintenance of the ignition system, I'd have the distributor tuned up and timed, change condenser and check the coil.
11-06-2019, 09:18 AM | #6 |
11-06-2019, 09:52 AM | #7 |
11-06-2019, 05:34 PM | #8 |
11-06-2019, 10:24 PM | #9 |
Thanks for all the educated thoughts. To answer some of the questions I replaced gas tank (sheets of rust inside and sediment bowl looked like I was running Jack Daniels), blew out fuel line, replace fuel pump and rebuilt the carb though I did not use the reworked Power Valve that Charlie suggests. Bought and installed a rebuilt coil (remote) done by Skip.
Correct distributor. This car had undergone a full restoration but have no specific details. It did not start after it sat for several hours, turn over yes, but won't fire. I did loosen gas cap and tried it but did not fire. I think I have a new condenser which I will try tomorrow. I'll keep you all informed as to how I do. |
11-07-2019, 03:17 AM | #10 | |
I have experienced this problem. Phil NZ |
11-07-2019, 02:21 PM | #11 |
Have you checked for spark to the plugs? If not, just remove a plug wire from the spark plug, attach to a used plug you have laying around (or remove one from the car). While cranking the engine, with ignition on, you should see a spark from the plug when touched to a metal service.
Spark should be bluish. If spark is yellow, you may need a new coil and/or condenser. If spark is bluish, your problem is probably fuel related. If no spark at all, you may need to look at the dizzy. Good luck, Last edited by 4t7heaven; 11-07-2019 at 04:21 PM. |
11-07-2019, 11:55 PM | #12 |
Yes, sediment bowl is full. Need to check plug for spark. Removed the condenser, OEM style, and have new one ready to go it.
11-08-2019, 10:00 AM | #13 |
If you can organize your trouble shooting in an "elimination" style, then you will know if a certain part is ok and not the cause of your problem. Going in and replacing several parts at once, may solve the problem, but then you will not know if those replaced parts were any good. I would suggest going one step at a time. Enjoy the journey and the satisfaction that comes with solving the mystery.
11-09-2019, 05:43 AM | #14 |
Send your coil to Skip for rebuild
11-09-2019, 06:57 AM | #15 |
After installing the new condenser, if the 'no start' condition persists, I would check fuel flow. The new tank was a good move but the crud in the old lines may be haunting you.
11-09-2019, 08:52 PM | #16 |
OK, the coil in my car is a Skip rebuild.
I did blow out the fuel line from engine compartment to the end of the line at the tank. Seemed quite open but still worth checking again. And yes I make only one change at a time and then try to start after each time. |
11-09-2019, 09:04 PM | #17 |
Do you have a fuel filter in the line?
11-10-2019, 10:13 AM | #18 |
Great question. Also, do you have the original style fuel pump or was an electric installed by the PO? If not, you may wish to install one at some point for reliability. That is, of course, you are not restoring this car to original.
11-12-2019, 12:37 AM | #19 |
No inline fuel filter, brand new original style fuel pump
11-12-2019, 12:43 AM | #20 |
Update: Checked for spark at the plug wire and nothing. Replaced coil, no change. Found I had 6V at the ignition switch with switch on, but it dropped to 4.5V at the coil.
Since I had installed a Columbia 2 speed rear this past summer I decided to take the wire connection off the back of the ignition switch just to make sure I had not compromised the wiring. In the process found that red wire terminal on the back of the ignition switch was very hot, hot enough to burn me. It was only hot with the ignition switch in the on position. I have not got into the distributor yet, that is next. But I am not sure what could be going on in the distributor that could cause this issue. |
