Old 11-05-2019, 04:50 PM   #1
pjdeb
pjdeb's Avatar
Default Odo Stuck - 1930 Round
Anyone had luck freeing it up? Pictures. Turning the gear by hand moves all but the last (left) wheels.
That small retaining spring looks tough to get off/on.
Anyone sell the assembly. Rest of the speedo is good.
pjdeb is offline   Reply With Quote
Old 11-06-2019, 07:30 AM   #2
ronn
Default Re: Odo Stuck - 1930 Round
just buy a rebuilt off papanick and sell yours off or use it as a core.
Old 11-06-2019, 01:46 PM   #3
31Tudor
31Tudor's Avatar
Or... No known website: Harry Warburton (252)-258-1530/(252)-752-4098 (N. Carolina)
He cleaned mine up, in a very reasonable time.
31Tudor is offline   Reply With Quote
Old 11-06-2019, 05:14 PM   #4
Mark in MT
Looks like a Waltham, the washer on the end will press off with a little effort. Done wrong and you can distort the wheels which will cause more binding. Nineteen pieces in the odometer assy, and they need to be timed or it will not work. Oft times the grease that the maker put in there 90 years ago has turned to concrete. A clean and lube is recommended, the tricky part is getting it all back together so that it works.
Mark
www.marksspeedometer.com
Mark in MT
Always looking for another opportunity to be wrong.
Mark in MT is offline   Reply With Quote
