Old 11-03-2019, 03:36 PM   #1
DannL
DannL's Avatar
Default Analyze this . . .
Cleaned these 30.6 miles ago. In order from cylinder 1 through 4. #1 was a little wet where I touched the edge with my finger. Thanks in advance.
DannL is offline   Reply With Quote
Old 11-03-2019, 03:45 PM   #2
F.M.
Default Re: Analyze this . . .
Running Rich...
F.M. is offline   Reply With Quote
Old 11-03-2019, 04:55 PM   #3
30 Closed Cab PU
Was this mostly around town driving? Could try a hotter plug. Had similar issue switch from 3076 to Champion W18s, helped quite a bit. Mine were not wet though
30 Closed Cab PU is offline   Reply With Quote
Old 11-03-2019, 05:48 PM   #4
Werner
Werner's Avatar
Hallo Dann,
the plugs image is not perfect but not bad. The rear two plugs are also less sooty at my engine than the two from the front. They work there with hotter conditions.
In order to judge the plugs images correctly, you should travel 20 miles quickly, turn off the engine without running idle. Then you can rate the plugs face correctly.
Modern spark plugs are heat tolerant, because they have a "spread" (= multi-range) heat value.
Beste Gruesse aus Deutschland,
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 11-03-2019, 05:58 PM   #5
DannL
DannL's Avatar
Thanks yall! 14 miles was at 35-40 mph (max that sounds comfortable). The rest was local in-town 30-35. I did shut her down directly after the 14 mile hike. Then pulled the plugs specifically to verify where I was with the GAV. It was only about 1/5 open for this test. Plugs are Champion W16Y.
Old 11-03-2019, 06:07 PM   #6
F.M.
Put in a set of 3X or W18 and try again, they are hotter..
Old 11-03-2019, 06:16 PM   #7
eagle
eagle's Avatar
You should be able to get a lean run with the GAV. Then open it up JUST enough to smooth out. Usually I close mine a bit more while cruising. If you can't get a lean run then you need to check into the carb cleanliness, jetting, etc. Also, pull the spark lever down until it pings, then retard it just enough to eliminate the ping.
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool."
eagle is offline   Reply With Quote
Old 11-03-2019, 06:41 PM   #8
WHN
What setting is your spark plug gap, 35?
They do look like your running mixture is to rich. How did the engine perform on your 14 mile run?
Does your engine feel like it is loading up when you accelerate? Are you using MMO in your gas?
WHN is offline   Reply With Quote
Old 11-03-2019, 08:28 PM   #9
DannL
DannL's Avatar
http://pvmafc.org/phpbb/viewtopic.php?f=8&t=3
Runs well in my opinion. Steady. Reached 40mph for the first time on the flat during that run. That was after 3 months of "fine tuning", and replacing every part under the sun.
.035 on the gap.
Loading up? Not sure about the meaning there. MMO? Is that a particular tasty batch of Moonshine?
Old 11-03-2019, 08:50 PM   #10
alexiskai
alexiskai's Avatar
MMO = Marvel Mystery Oil
Old 11-04-2019, 12:32 PM   #11
WHN
.035 on the gap.
Loading up. I was asking if the car seemed to hesitate (not firing on all cylinders) as you accelerate.
If you think it is performing well. Than I would try a hotter spark plug first.
Years ago I bought a set of plugs that I didn’t know were wrong. They looked right, fit right. After running them for a few miles they looked like yours, I needed to clean them every 30 miles or so. I don’t believe that the plugs could have been the problem. They were after all new. Changed plugs, everything is fine.
Old 11-04-2019, 12:49 PM   #12
DannL
DannL's Avatar
I've ordered some "other" plugs. We'll see how they perform before I reveal what they are. A fool and his money are soon parted. :-)
Old 11-04-2019, 04:43 PM   #13
Humperhill
In my opinion, if its running well maybe leave well enough alone. That last plugs look like you could end up too lean in a heart beat if you start leaning out the fuel/air mixture. However my experience with these motors specifically is very limited.
Humperhill is offline   Reply With Quote
Old 11-05-2019, 09:13 AM   #14
Big hammer
Looks to me #4 is running leaner, check for intake leak. All of your plugs should look the same!
get a bigger hammer tap done
Old 11-05-2019, 01:09 PM   #15
Werner
Werner's Avatar
If there is a intake-leak, then must run #3 leaner too.
Werner
Citroen 11 CV, 1947
Old 11-05-2019, 01:22 PM   #16
30 Closed Cab PU
.035 on the gap.
If running MMO (Marvel Mystery Oil) in the gas, sometimes plugs will show additional deposits than if running without it.
It is used to counteract effects of corn (ethanol) gas, provides a little upper end lube, keeps valve from sticking, and helps Carb float needle seating, may be other advantages. Usually added 4 ounces per tankful.
Sometimes added through the intake vacuum port or through the carb air intake to free sticky valves.
Old 11-10-2019, 12:35 PM   #17
DannL
DannL's Avatar
Well, to my dismay the Autolite 3076 plugs did not help. They did make the engine sound like it was firing more assertively during idle but . . . on the road any time you would give it gas the plugs we're randomly misfiring. Went back to the Champion W16Y plugs and all is normal. Ordered some W18's and will see if that makes a difference.
Old 11-10-2019, 01:06 PM   #18
30 Closed Cab PU
The W16s and 3076 are almost equivalent range plugs for RPMs on an A. The W16 are kinda a dual range plug, they are colder at below 2000 rpm, but hotter above 2000 RPMs for more modern motors.
If you do not read how W16 plugs are designed, the W16 plugs appear to be hotter than a W18, but in an A the W18s are actually hotter than the W16.
Old 11-10-2019, 01:48 PM   #19
F.M.
Re-read posts #3 & #6
Old 11-10-2019, 02:56 PM   #20
DannL
DannL's Avatar
I had found a plug cross reference that put the 3076 up there with the W18. I guess we'll find out soon enough.
