#1 |
I have 8BA in a 40 deluxe and would like to change cams in the car. I would love to hear all your tricks. Oh I don't want to take the heads off, thanks Chuck
#2 |
I believe this was in a thread last week. Most agree it is easier to pull the engine.
#3 |
Not easy to do and lots can go wrong! But, it can be done (even if it is doing it the hard way!).
#4 |
Chuck, I told you how to do this last week when you asked....
#5 |
Brian, thanks for the come back, I have more than one flathead so I completely forgot about the 49 cam question. Both of these cars have freshly rebuilt 8BA's and they both have low oil pressure, 5lbs., at idle when warm, sometimes 0. The cams were reground and I think they may have turned the journals. The machine shop replaced the bearings with standard bearings so there could be extra clearance there. It is my fault, for not checking the cam. The engine is totally quiet , no unusual sounds, i have two oil gauges on each of them. I have about 5k on both of them with no changes, thanks for your help, Chuck.
#6 |
Ronnieroadster
I use the F word a lot no not that word these words Flathead, Focus and Finish "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587 |
#7 |
When I get a camshaft reground, because the grinding operation takes place between centres, I then get the journals ground undersized to fit the measured dia of the newly installed undersized bearings. This ensures perfect concentricity of the cam lobes.
