Old 10-26-2019, 06:11 PM   #1
Walter Ezzell
Default Early Model Radiator and Gas Caps
Can anyone tell me how to identify the early AR Radiator and Gas caps. Seems like I remember that there was a difference in the AR ones versus later ones.
Walter Ezzell is offline   Reply With Quote
Old 10-26-2019, 08:02 PM   #2
Gary Karr
Gary Karr's Avatar
Default Re: Early Model Radiator and Gas Caps
Early caps were either low domed or high domed. The high domed caps were actually spot welded together, which should be visible inside the caps.
Gary Karr is offline   Reply With Quote
Old 10-28-2019, 12:02 PM   #3
1955cj5
1955cj5's Avatar
Here are a couple of gas cap pictures. The first is of an early 1928 cap, the second is the later version, 1928-1929.
The Judging Standards has drawings on page 15-8 Revised 2016.
The early ones are spot welded with an almost flat dome, the later caps are soldered with a higher dome.
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
