10-25-2019, 02:56 PM | #1 |
Speedo cable
The speedo cable in my 51 ford broke. I replaced with a new one. After 1/2 miles driving in broke again.Both times making noise in the dash.The gear in the trans is okay so I think the problem is in the speedo.It seems as if something is locking up in speedo,can that be fixed.It twist and brakes off at the back. Thanks for your help
10-25-2019, 03:55 PM | #2 |
Re: Speedo cable
That is correct, Speedo stops turning and drive does not! Also very common in Model A's.
10-25-2019, 04:17 PM | #3 |
Re: Speedo cable
lube the speedometer input shaft , there should be a small pressed in plug near the threaded area on top of the cable input area on the speedo head , remove the plug lube the wic and turn the cable input shaft and see if the input shaft becomes easier to turn , I don't have a pic available maybe someone will post a picture.
10-26-2019, 12:06 PM | #4 |
Re: Speedo cable
Most speedometers rely on the die cast housing to hold the cable in place. After years and miles, they often permit the cable end to wobble, binding and breaking the the inner cable.
10-30-2019, 02:47 PM | #5 |
Re: Speedo cable
what it is the speedometer needs serviced to clean the bushing up and lubed.
10-31-2019, 01:49 PM | #6 |
Re: Speedo cable
10-31-2019, 06:06 PM | #7 |
Re: Speedo cable
I would like to help you out can you email a photo of your speedometer. [email protected]
Then I can see what you have. |
11-03-2019, 11:41 AM | #8 |
Re: Speedo cable
Thanks ..I have the info that I needed.
