10-17-2019, 10:54 AM | #1 |
50 Ford Fresh Air Vents
I see cables open and close the fresh air vents on driver and passenger sides of the car. Where are these cables controlled from? I am not seeing a place in the dash or above the kick panels..
Thanks, Steve |
10-17-2019, 11:02 AM | #2 |
Re: 50 Ford Fresh Air Vents
One is to left of the steering column and the other is the vent selection on the heater control.....Mark
I'm thinkin' about crankin' My ragged ol' truck up and haulin' myself into town. Billy Joe Shaver |
10-17-2019, 01:43 PM | #3 |
As flatford8 says.
10-17-2019, 07:23 PM | #4 |
My 50 didn't come with a heater, the fresh air controls were on each side of the column.
Greg |
10-17-2019, 08:59 PM | #5 |
That's what I was kind of wondering. Mine was missing a heater and a firewall plate over where the heater would be. I do have a heater that I am installing, additionally there was a plate on the column with 2 holes in it. This would be the location of both fresh air controls were there not a heater but now left one would be on the column and the right on the heater control under dash?
10-18-2019, 05:14 AM | #6 |
Greg |
10-18-2019, 05:17 AM | #7 |
On mine I have used the right hole for my fan switch, I installed the same knob on both. I got the push pull switch from NAPA I think.
Greg |
10-18-2019, 01:31 PM | #8 |
Look up heater parts in the Dennis Carpenter 49-51 Ford parts catalog. There is a good diagram of what is supposed to be there. Greg58-it looks like you are missing the air valve damper assembly. It deflects the fresh air either thru the heater or by passes the heater. Good luck with your projects!!
10-18-2019, 07:23 PM | #9 | |
Greg |
10-19-2019, 12:41 AM | #10 |
10-19-2019, 06:11 AM | #11 |
No problem, sometimes you have to work with what you have. I've noticed that the heater core still gets warm from heat transfer through the coolant on the return line, that's the reason for dual cutoffs under the hood. When it gets 95° here I need all the cool air I can get.
Greg |
10-19-2019, 06:18 AM | #12 | |
Greg |
10-19-2019, 10:21 AM | #13 | |
