Old 10-06-2019, 11:24 AM   #1
Russ/40
Russ/40's Avatar
Default Rear main tube?
Is there a way to confirm the rear main tube is in place, without dropping the pan?
Russ/40 is offline   Reply With Quote
Old 10-06-2019, 11:49 AM   #2
Purdy Swoft
Purdy Swoft's Avatar
Default Re: Rear main tube?
None that I know of .
Old 10-06-2019, 12:14 PM   #3
Joe K
Joe K's Avatar
I had one break off. I know this because I found the tube in the bottom of the oil pan when it was down and apart for other reasons.
I think if your rear main gasketing/cork is all in place and tight you probably would never know either.
Joe K
Shudda kept the horse.
Joe K is offline   Reply With Quote
Old 10-06-2019, 12:28 PM   #4
Fullraceflathead
Fullraceflathead's Avatar
Maybe? You might be able to insert a bore scope camera thru the drain plug hole then carefully maneuver it towards the rear main bearing area. You can buy these small bore scope cameras for smart phones on EBay for under $10.00.
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 10-06-2019, 04:08 PM   #5
old31
I agree, the scope camera is the only way that you will be able to look for the tube.
Old 10-06-2019, 04:41 PM   #6
Kurt in NJ
Kurt in NJ's Avatar
The pan has baffles that would make it harder to see
Does it leak--?
Old 10-06-2019, 05:49 PM   #7
Russ/40
Russ/40's Avatar
Does it leak--?
Yes, I have a big time leak. After a 20 mile drive, it drips what looks like 3/4 of a cup. I put the engine together, but honestly don't remember what I did or didn't do regarding the tube. Prior to building this truck, all my experience was with flathead 8s. Only learned of the importance of the rear main tube and oil leaking was after finishing the entire drivetrain.
Trying to remember, is the tube visible under the pan tray or do you need to see above the tray? I would think a scope would be more maneuverable below the tray from the drain plug.
Old 10-06-2019, 07:44 PM   #8
redmodelt
redmodelt's Avatar
Pull the oil fill tube and run the scope in there. Don't have to lay on your back under the car nor drain the oil. Plus it is a bigger hole to work thru. Don't forget, there are the baffles that stick down so you would have to work under them from the bottom. Ok so I read the whole thing and missed Kirt in NJ's post of about the same thing Re the baffles.
