Old 10-04-2019, 07:06 AM   #1
morebeer
Default windshield tape
I'm installing a new windshield on my 31 Roadster and wondering if anyone has used this tape https://www.bobdrake.com/glasssettingtape and how well it worked.
morebeer is offline   Reply With Quote
Old 10-04-2019, 09:13 AM   #2
nick c
Default Re: windshield tape
I don't know anything about roadsters, but I do know about a 29 ccaa truck windshield install. The Model A suppliers sell bedding tape .048 thick, it was a snug fit, my frame was sandblasted, primer and paint, used soap and water to lube, used a bar clamp and a piece of wood with a slot cut in it the width of the glass, what a pain it was.
carry on
nick c is offline   Reply With Quote
Old 10-04-2019, 09:44 AM   #3
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
You might as well use the correct stuff. Mitch on one of the other forums and sells some setting material that looks pretty close to the original stuff. I would use his instead.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 10-05-2019, 07:56 PM   #4
updraught
updraught's Avatar
If your frame is getting thin, you may want to take it to a glass man and have him silicon it in.
It will help hold it all togther.
Not original, but a bit like those new ceramic tooth fillings that are carved from a block and glued in, and hold your tooth together. And they taste better than the old ones made from mercury.
updraught is offline   Reply With Quote
Old 10-07-2019, 08:08 AM   #5
burner31
burner31's Avatar
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Old 10-23-2019, 11:54 AM   #6
morebeer
Took a while to track down the source for original type tape. Here's a link fyi:
https://www.ebay.com/itm/20160623563...84.m1555.l2649
Old 10-23-2019, 02:02 PM   #7
BRENT in 10-uh-C
That is Mitch that is selling it in that auction. I mentioned contacting him in post #3. He is the Administrator of the Forum that is mentioned in the eBay listing.
BRENT in 10-uh-C
Old 10-23-2019, 03:54 PM   #8
morebeer
Yeah. Thanks. You pointed me in the right direction.
