Old 09-21-2019, 11:29 PM   #1
31Abone
31Abone's Avatar
Default 32 to 48 v8- are fuel pumps the same
Can I buy any rebuilt v8 fuel pump 32 to 48 and expect it to be correct ??
31Abone is offline   Reply With Quote
Old 09-21-2019, 11:37 PM   #2
ford38v8
ford38v8's Avatar
Default Re: 32 to 48 v8- are fuel pumps the same
That's a pretty wide open question. Can you narrow it down some?
Alan
Old 09-21-2019, 11:49 PM   #3
Charlie Stephens
The Green Bible lists 59A 9350-A as fitting 1932-1948 passenger 90 and 100 HP. This says it should work but not necessarily be correct for a high point restoration.
Charlie Stephens
Old 09-22-2019, 12:51 AM   #4
Marvin/TN
Send a message via AIM to Marvin/TN
Been a long time but I think I bought what was listed as a 34 pump for my 46 59 AB, does not have the sediment bowl.
Marvin/TN is offline   Reply With Quote
Old 09-22-2019, 10:05 AM   #5
DavidG
DavidG's Avatar
Only with '34 or later intake manifolds and fuel pump stands/oil filler tubes. '32 and '32 intake manifolds require modifications plus the '34 and up fuel pump stand/oil filler tube and a different fuel pump push rod. The fuel pump to carburetor line on '32-'33s would also have to be modified or replaced.
It would be helpful if you stated what engine and intake manifold you have in mind as well as what you mean by "correct"; functionally speaking or as built?
Old 09-22-2019, 04:27 PM   #6
31Abone
31Abone's Avatar
I think my motor is a 35 ..it has the 97 type manifold and gen setup..sc
Old 09-22-2019, 04:38 PM   #7
Charlie Stephens
The 97 is a 2 barrel Stromberg carburetor, is this what you are trying to say? Is is correct to assume you have a fuel pump on there with the correct height stand and length push rod? You are asking if you can buy a rebuilt fuel pump to use as a spare and expect it to be a bolt on if you need it? How about a picture of the one you have? It might be a minor amount of work (lines?) to get it to fit but you don't want that on the road, check it first.
Charlie Stephens
Old 09-24-2019, 07:10 PM   #8
FireEngineMike
FireEngineMike's Avatar
Better choice is to have charlie ny rebuild it.
FireEngineMike is offline   Reply With Quote
Old 09-25-2019, 01:09 PM   #9
31Abone
31Abone's Avatar
Found out what I wanted to know ..34 to 48 fuel pump for caustic new fuels will work just fine..thanks much..my pump looks new and shiny brite thot maybe from china but i guess a rebuilt type without sediment bowl..sc
Old 09-25-2019, 03:41 PM   #10
supereal
supereal's Avatar
Fuel pumps many be similar, but the push rods vary between years, and whether the intake manifold is iron or aluminum, and the mount is correct. Any small variance can have a big effect on performance.
supereal is offline   Reply With Quote
Old 09-26-2019, 07:24 PM   #11
Tinker
Tinker's Avatar
Don't the pumps with the glass bowl start later. Like in the 40s. I like them and run one on my 38. 36 has the standard no bowl.
An old wise/wives tale but if you replace the gasket with a cut playing card you add pressure. Maybe so... not likely. But I like the ace of spades or the 2 of diamonds.
