Old 09-21-2019, 11:06 AM   #1
Lefthander1930
Lefthander1930's Avatar
Default Drivers door sag
My drivers has a little sag & is now rubbing the door against the jam. I will replace the pins the see if this cures or helps. If not what Next ?? Just looking for a little Help.
Thanks
Lefthander 1930
Lefthander1930 is offline   Reply With Quote
Old 09-21-2019, 11:20 AM   #2
Purdy Swoft
Purdy Swoft's Avatar
Default Re: Drivers door sag
If the hinge pins are worn smaller than the holes in the hinges , replacing the hinge pins will help . Usually springing the door is an easier fix than trying to adjust .
Old 09-21-2019, 11:24 AM   #3
nick c
When I finished restoring my 29 ccaa, I had the same problem, had to place 2 shims under cowling per side, made from 1/4" conveyor belt, each side of cowling has a front and back hold down bolts, if you only shim the back it will pick up door but the hood may not line up with cowling, trial and error is how I got mine to work.
carry on
nick c is offline   Reply With Quote
Old 09-21-2019, 01:08 PM   #4
mike657894
mike657894's Avatar
look at the dove tail that mates up with a slot. there are some wear parts in there. I would replace the pins at the same time.
mike657894 is offline   Reply With Quote
Old 09-22-2019, 07:56 PM   #5
Tinbasher
Tinbasher's Avatar
First check and make sure the pins or hinges are worn. It there's no movement when you lift up on the door then you need to shim the rear cowl bolt to lift the door. JP
Tinbasher is offline   Reply With Quote
Old 09-30-2019, 07:09 PM   #6
Lefthander1930
Purdy,
How do you spring the door/hinge ? My door has a little play lifting up & down.
Thanks
Lefthander1930
Old 10-01-2019, 11:02 AM   #7
Purdy Swoft
Originally Posted by Lefthander1930 View Post
Purdy,
Thanks
Lefthander1930
If the door is sagging at the rear lower area I place a block of wood wrapped in a shop rag in the door jam , in the area of the lower hinge . When pushing the door too , (NOT enough for the door to latch ) springs the lower hinge back and raises the rear of the door . Care must be taken not to go too far or it gets more complicated . You will probably need to experiment with different thickness of the wood or whatever is placed at the front door jam in the area of the lower hinge . If the wood is too thin it won't do much of anything . There is no sliding adjustment for the doors , Springing the hinge is what I do . Springing the lower hinge backward raises the rear of the door . Shimming the cowl is sometimes the way to go . Removing shims at the front of the cowl raises the door at the rear . If removing shims at the front doesn't do the job , adding shims at the rear of the cowl will raise the rear of the door to remove sag . I loosen all body bolts nuts almost completely. I use a long Craftsman screwdriver under the body block to prize ihe body block upward for the necessary clearance to remove or replace the shims .I prefer prizing the body blocks up for clearance rather than raising the body .
Old 10-01-2019, 05:36 PM   #8
tinman7
tinman7's Avatar
Should you remove the hinge first and get the pin out on the bench or try to get it off in place? My roadster hinge pins are very worn and I am trying not to ruin the paint if I can help it....
tinman7 is offline   Reply With Quote
Old 10-01-2019, 06:09 PM   #9
Mike Peters
Mike Peters's Avatar
To tinman 7:
https://www.brattons.com/catalogsear...nge+pin+remove
Mike Peters is offline   Reply With Quote
Old 10-01-2019, 06:50 PM   #10
tinman7
tinman7's Avatar
Thanks Mike, I have a similar pin remover but it won't work on the top door hinge so I guess I need to remove the hinge? Anybody else run into that?
