#1 |
Just interested in how much oil is used up in a decent engine? Lets say 65psig for compression in each cylinder and very few leaks. I know there are lots of variables. My engine has roughly 45,000 miles on it. I use a 1/2 quart in 200 miles. Wondering if that is normal? I don't hear any unusual noises either.
#2 |
1/2 quart/200 miles?
#3 |
Maybe a little less.
#4 |
Good afternoon...So you would use about one quart in 500 miles between oil changes...does not seem excessive to me. With our 31 Tudor we find that it will toss out 1/4 quart or so if we fill it to the top mark on the dip stick. If we fill it to about 1/4 inch below the top mark, it uses much less as it is not tossing it out of the rear main...other opinions/experiences will follow...
#5 |
Mine seems to use no oil in 500 miles. I change it at 500 so I don't know how far it would go.
#6 |
Our 29 does about the same. Compression is also 65 psi average for all four cylinders. I run 20w-50 Walmart oil, four quarts with one 16 oz. Bottle of blue STP. That fills crank case to the full line on dip stick. We have very little dripping, but she will mark her spot. Engine was rebuilt under 10,000 miles ago. Believe it or not, rebuilt in late 60’s. Enjoy. |
#7 |
Is your engine using it or losing it? Are there clouds following you as you drive? When you add oil do you stop when it reads full on the dip-stick?
#8 |
I change about every 1000 miles. Can't see any change on the dipstick at that interval. I fill it to the full mark. Doesn't really leak though, just enough to get oily on the bottom, not enough to drip. I wouldn't get excited if yours goes through a qt at 200 miles, just watch the dipstick and don't let it run low. As long as the plugs aren't fouling or you're not leaving a trail, it won't hurt anything.
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool." Last edited by eagle; 09-09-2019 at 10:33 PM. |
#9 |
I use no oil in between 500 mile oil changes but my engine is fairly fresh at around 6000 miles.
So to me that is not a good comparison to your engine that has 45,000 miles on it. Only WHN has indicated how many miles on his engine. Need to compare apples to apples on this one. Try filling it to halfway between L and F to see if that makes any difference. No harm will come from keeping it at that level.
Dave / Lincoln Nebraska |
#10 |
At 45,000 it might be a good time to re ring,lap valves and check bearings,catch it right and you can do an overhaul without going to the machine shop,freshen her up.
#11 |
I do not see any smoke out the exhaust. I do see a small drip on the transmission plug thought. No blow-by from the filler either. I thought I read somewhere that due to the splashing of the oil on the cyl. walls some oil is lost but can't find that info again. I think the advice here on the thread is good advice. For now I will just keep an eye on things but during the winter may pull the motor and remove the head to check things out.
#12 |
Drip on the transmission plug is normal if it is motor oil as the motor oil makes its way to the radius ball to lubricate it.
"The more things change, the more they stay the same." |
#13 |
I change oil at about 1,000 miles and don't need to touch it between services. The level has fallen by the time the next oil change comes around but that only means less used oil to dispose of. I'd guess it would take about a litre to get back to the full mark. Motor has done about 45,000 HARD miles (towing).
One litre is so close to one US quart that it doesn't matter.
I sometimes wonder what happened to the people who asked me for directions. Even at my age, I still like to look at a young, attractive woman but I can't really remember why. |
#14 |
Try this, don't put in any oil and drive another 200 miles and see if it goes down any more.
#15 | |
![]() Quote:
Good advice. I'm guessing you fill it right up to full on the dipstick? My old engine didn't burn any oil and neither does the new one but if I filled them up to the full mark on the dipstick both would drip. The old one liked to be 1/4" below F. Haven't learned where the new one likes to sit but it's probably similar. Much like the radiator, engine oil will find its own level. |
#16 |
My car will toss out about a 1/2 quart if I fill to the full line. If I leave it alone afterwards
it doesn't use any more. Try burning the first 1/2 quart and then keeping an eye on it and see if it stops or slows down. |
#17 |
My thought also is that it could be throwing out a certain amount of oil until it finds its happy place. Some engines are kinda fussy about such things. Try running a 1/2 qt low for awhile [if your up to that mental stress] [smiley face].
If the engine is running some oil will find its way out the rear main. If the engine is good otherwise, I'd run it and add oil. |
