#1 |
I have my new latch all greased up and trying to install it. I understand
that the "U" part of the latch spring needs to go in behind the door metal. Is there a tool any of you use to push the spring back far enough to clear the opening? I have tried a screwdriver, but it slips off too easily. |
#2 |
I figured out a way.......I used the flat end of a large file to push the spring back away from the opening. After that, a simple tap let the latch pop into place. It works perfectly! Maybe 90 years from now someone will have to do this over. Not worried about that myself. Love this hobby!
#3 |
I bent the end with some needle nose pliers in such a way that maintains its tension against the assembly, but tucks up behind that ridge on the latch. So far it’s working great.
#4 |
