#1 |
My 59ab with 2 bolt crab started acting up. Points were oil soaked. Sent to Skip and he found the shaft bearing support by the rotor to be cracked. He replaced the shaft assembly and the plate assembly with a good bearing support. After a few miles car started running poorly only to find the new bearing support completely broken.
Any ideas on the oil soaked problem and 2x broken bearing support. Thanks |
