Old 08-22-2019, 07:42 PM   #1
Bob56
Default Safety Wire
What gauge is the annealed safety wire for the bolts that hold the fuel tank on 1936 Club Cab
Bob56 is offline   Reply With Quote
Old 08-23-2019, 06:41 AM   #2
36rgtop
36rgtop's Avatar
Default Re: Safety Wire
What ever fits in the hole?
36rgtop is offline   Reply With Quote
Old 08-23-2019, 12:05 PM   #3
rotorwrench
rotorwrench's Avatar
It's close to baling wire size like .040" or so. Soft black steel wire is out there is different gauge sizes but not like it used to be. I've seen the smaller rolls called steel stone wire. Aircraft safety wire is mostly stainless steel but it comes in convenient diameters and small rolls. It's more expensive that the plain steel stuff.
Old 08-23-2019, 02:22 PM   #4
Bob56
Thanks for the reply. I found the stainless wire all over the place but having a hard time finding annealed wire and I didn't know what gauge
Old 08-23-2019, 02:51 PM   #5
Marvin/TN
Send a message via AIM to Marvin/TN
Just use the stainless, one roll will last you a life time and will never rust. Wish I had a $100 for every inch of safety wire that I have used.
Marvin/TN is offline   Reply With Quote
Old 08-23-2019, 03:30 PM   #6
51 MERC-CT
51 MERC-CT's Avatar
Stainless steel safety wire is in an annealed condition.
As previously stated, measure the hole in the bolt to find the size you need
or take the bolt to the hardware store to check the fit.
Old 08-23-2019, 05:24 PM   #7
ford38v8
ford38v8's Avatar
Rebar Tie Wire is 16 gauge. "Available at all your finer hardware stores".
Alan
Old 08-23-2019, 06:39 PM   #8
37 Cab
37 Cab's Avatar
We need a "like" button.
Tommy
37 Cab is offline   Reply With Quote
Old 08-23-2019, 06:43 PM   #9
rotorwrench
Rebar wire is near .062" so it's pretty large diameter. It may not fit in smaller bolts. If it has a hole bigger than 1/16" it may work OK. I think the standard is 16.5 gauge witch is kind of a strange size. In aviation, the .040" and .032" are generally the most common for safety wire. I use .025" for cannon plugs and small screws.
Old 08-24-2019, 10:55 AM   #10
Kerk
A.F. was mostly 032 dia. Still have some. Thanks all!
Kerk is offline   Reply With Quote
Old 08-24-2019, 01:15 PM   #11
DavidG
DavidG's Avatar
If you've ever wrestled with installing the wire in the recess on the back of a transmission or torque tube you know too big or too stiff wire is a very bad idea.
