08-20-2019, 04:13 PM | #1 |
64 Galaxie rear leaf spring
OK, has anyone dealt with replacing the rear leaf springs on a 64 Galaxie. The front hanger 5780 stud assembly is buried inside the 5775 spring hanger. I have done everything but torch it, which I prefer not doing since it could weaken the frame.
08-20-2019, 10:10 PM | #2 |
Re: 64 Galaxie rear leaf spring
Most likely the bolt is rusted into the spring eye bushing, 5737. You may not have a choice but to snip it apart with a torch. If you are careful you won't damage/weaken the frame
08-20-2019, 11:12 PM | #3 |
I had a similar problem with a 55 bird when I broke the main leaf. An old friend who’s a very experienced mechanic told me to heat it red hot and let it cool. Repeat as necessary.
He said the expansion and contraction of the hot bolt or nut eventually broke the rust loose. You didn’t have to melt it out. Last time I used that was a couple years ago on an OT 56, the bolt thru the spindle to the steering arm. Took 5 or six cycles, then it broke loose and came out. We did not reuse the bolt or the nut. |
08-21-2019, 08:14 AM | #4 |
Can you get in there with a saw-zaw ?
08-21-2019, 09:06 AM | #5 |
sawing it off will not solve the problem. He will still have rusted bolt shank stuck inside the bushing.
I had the same issue on my '55 bird. I sprayed penetrant on it each day for about a week. I heated the bolt ends with a Mapp gas torch. It was enough heat. I put a wrench on the bolt head (six point is best). Just gave some taps with a hammer in both directions. Did not try to persuade it all at once. An impact wrench and socket would be good also. I applied more penetrant. Went back the next day with some more heat and applied the wrench again. I got it loose on the third day and was able to use a drift pin to drive the bolt out. Then I cleaned out the bushing thoroughly. I even got a slightly smaller drill and ran it through a few times. I got it so the new bolt would slide in without binding and then coated with anti-seize when I reassembled. |
08-22-2019, 06:49 AM | #6 |
08-22-2019, 02:02 PM | #7 |
I did my '59, the nut came off and I used a drift to drive the bolt out. If the bolt is stuck you could try an impact hammer with a flat punch on it.
