05-23-2010, 09:17 AM | #1 |
Heat Shield for Speedo Cable
Although I love the sound of headers and Brockman's Mellow-Tones, I am almost convinced the heat from a small area to where my speedo cable routes through on the driver's side pipe is giving causing my speedo needle bouncing problem. When I pulled out the inner cable, it was very hot. The cable is clean, lubed and works great for a few minutes but after everything gets warmed-up, here comes the noise and bounce. Any suggestions om material that would work well as a heat shield? I was thinking either exhaust wrap or high temp hose (catylitic coverter type) that I could surround that small portion of the cable. I'm not ruling out that my speedometer may need a rebuild but want to exhaust (pardon the pun) every means before dropping a few hundred dollars.
If it aint broke, don't fix it! |
05-23-2010, 09:48 AM | #2 |
Re: Heat Shield for Speedo Cable
Sometimes a speedo needle bouncing problem is from a kink in the inner cable, take the inner cable out and roll it on a flat surface, if it all rolls smooth it is not kinked, but if 1 spot bumps that is a kink---carefully straighten it until it rolls smooth.
05-23-2010, 05:16 PM | #3 | |
I don't think that you need the heat shield. |
05-23-2010, 05:26 PM | #4 |
Thanks; I'll give it a try although I will admit I'm not looking forward to working in that crampt area!
05-23-2010, 06:34 PM | #5 |
Go to the hot rod shops or speed shops - they have wrap that can be installed.
05-23-2010, 07:40 PM | #6 |
