#1 |
I'm hearing a flex fuel line from the fuel pump available with a one way valve.
On mine the fuel runs back to the tanks after shut down |
#2 |
Check valves in the pump should prevent that. or you have a leak close to the pump.
Robert Shewman P.O. box 163, Kimberton PA 19442 More info here on the check valve flexhose... https://www.fordbarn.com/forum/showt...se+check+valve |
#3 | |
![]() Quote:
That's simply a "band aid" approach to patching vs. a correct repair. Do yourself a favor and send your pump to Charlie. He'll rebuild it PROPERLY and return it quickly to you.
#4 |
fuel pump is 6 months old. Thanks
#5 |
Was it rebuilt? If so, by whom? When? Is it a reproduction?
