Old 08-15-2019, 07:50 AM   #1
Robert/Texas
Robert/Texas's Avatar
Default Head Gaskets
I’m replacing the head gaskets on my 1937 Ford as one side was leaking and the other had a stripped spark plug hole. Both heads are in a machine shop now, having the surfaces ground and the repair done. The engine was overhauled in 1955 and they used steel faced gaskets.
I see that copper gaskets cost more than the steel ones. Which would you suggest using?
All suggestions/advice will be appreciated.
Thanks, Robert
Robert/Texas is offline   Reply With Quote
