05-23-2010, 08:44 AM | #1 |
Transmission Fluid
Whats the best way to drain and refill the transmission?? Its been a long time, but is there a plug on the bottom to drain it and can you just pour it out from the can?
Thanks, Tom... Last edited by Tom F OHIO; 05-23-2010 at 09:04 AM. |
05-23-2010, 08:56 AM | #2 |
Banned
Re: Transmission Fluid
Well for me, I got her up on all four jack stands. Sitting level.
Ran her in 2nd till warm. Dumped out the old 600w. Then refilled with new 80/90 hypoide stuff, plugged her up again. Ran her till warm [20 minutes]. Dumped out this lube. Let her drain for an hour. Pumped in another virgin load of 600w. Take her off the jack stands. Good for another couple of years. I also did the rear axle the same way at the same time. And topped off the steering box with 600w. Hint: I have a 1 qt bottle with a plunger pump that screws on to the bottle [a lower end out board oil change kit from West Marine] and has a 18 inch hose that I slip into the fill hole and squeeze in all I can till the lube comes out the fill hole. Let her drip a bit and plug it up. It's a good work out for the thumb!! I don't pull the floor boards or take the tranny top off. I just might drop something in there. I tried mean-'O-Mr Gravity and the funnel...way too slow and messy. I also pulled a magnate through the drained oil to see if any ferrous specks stuck to the magnate. Nothing. skip. Last edited by skip; 05-23-2010 at 09:18 AM. |
05-23-2010, 09:06 AM | #3 |
I have always had good luck with the plug on the bottom for draining, for filling the easiest has been when i had the shifter tower off and poured the oil in the top before reinstalling the tower, the next easiest is using the fill plug with a funnel when the floorboard is out.
The method I like the least is laying on my back pushing the oil in with a suction gun---it is slow and messy. |
05-23-2010, 01:45 PM | #4 |
Good money well spent is the tranny dipstick kit. Cut out the floorboard (template), fix the tube into the pour hole. Ask your 600 wt.vendor for a screw on pour spout (think old fashioned plastic mustard bottle) and top ups/refills are simple. Use a funnel to add a little STP if so inclined. Simple to check fluid level and ensure you aren't losing fluid.
05-24-2010, 06:47 AM | #5 |
Warming the 600W
I have warmed up the 600W oil in the microwave prior to filling the trans/diff.
a 4 cup kitchen measuring cup for 7 minutes in the microwave. The oil then pours nicely into the suction gun and presses easily into the trans or differential. Hope this helps |
05-24-2010, 11:06 AM | #6 |
05-24-2010, 12:29 PM | #7 |
I HAD one of those tranny dip sticks but I removed it, keeping the handy inspection port in the floorboard similar to the battery inspection port. The dip stick with its six inch plumbing nipple tube was a pain compared to just using a long funnel and looking to see the fluid level in the tranny.
05-24-2010, 12:49 PM | #8 |
Ford said to drain the transmission, flush with kerosene, then refill with 600W oil, which is about the same as 240 weight gear oil.
05-24-2010, 01:22 PM | #9 |
NEVER user any type of Hypoid oil in the trans or rear end.
!! It will not cling to the gear faces and you will destroy the case hardening. |
