Old 07-25-2019, 05:27 PM   #1
NZ28ModelA
NZ28ModelA's Avatar
Default Laycock overdrive - Speedo drive
Greetings fellow A Drivers!
I had sourced a spare driveshaft and torque tube and Laycock overdrive from a Triumph gearbox and had them mated together by a local engineer. i will be fitting it to my pickup in the following few weeks.
Can someone please tell me where I attach the speedo drive, andwhat we do to keep the speedo accurate?
All help is appreciated
Kindest regards
Steve
NZ28ModelA is offline   Reply With Quote
Old 07-25-2019, 06:55 PM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: Laycock overdrive - Speedo drive
I thought originally it was in the tail housing on the laycock
there are speedo gearboxes for truck rears that are 2 speed
Old 07-25-2019, 08:52 PM   #3
briphaeton
My is hooked up to the original Model A setup on the torque tube, when in overdrive it's 10 miles an hour slower than the speed your going.
briphaeton is offline   Reply With Quote
Old 07-25-2019, 10:21 PM   #4
daveymc29
daveymc29's Avatar
We bought two from a fellow near Shafter/Bakersfield, may have been "Dave" something. His had a connection that ran off the back of the Laycock and tied together with the Model A and was very accurate. Someone chime in with his contact info, I have misplaced it. (Brentwood Bob may help?) I would love to buy another. Great units, one switch operation if you create the failsafe as I did in the latest Restorer, for my Borg Warner O/D. Silent and smooth.
daveymc29 is offline   Reply With Quote
Old 07-26-2019, 12:54 PM   #5
Herb Concord Ca
Rich Little is THE Laycock overdrive guy, lives near Bakersfield CA phone is 661-809-3451.
The over drive has a speed takeoff point,just need a speedo shop to make you a longer cable. The speedo gears are color coded, I thing mine is black, which matches the speedo very close. Other colors are available.
Enjoy
Herb Concord Ca is offline   Reply With Quote
Old 07-29-2019, 09:06 PM   #6
Doug Linden
Doug Linden's Avatar
Thanks Herb for the info on the color of the drive gear. My OD is off about 15 MPH and I figure I need to change that gear. I will keep my eyes open for a black one.
Doug Linden is offline   Reply With Quote
Old 07-30-2019, 04:33 PM   #7
Gavin
Steve,
If you were to provide your email address I will pass it on to a friend in Auckland who has sorted my Laycock speedo drive for me. He is not on this forum but has offered to help. Cheers Gavin
Gavin is offline   Reply With Quote
Old 07-30-2019, 06:35 PM   #8
Amyth
Kindest regards
Steve
Hi Steve - Give me a call on 0274949905 and I may be able to tell you if you can run an accurate speedo or not - I run one which is absolutely correct in both speed and distance Steve Driver
Amyth is offline   Reply With Quote
Old 07-30-2019, 06:38 PM   #9
Amyth
Hi Steve
Give me a call on 0274 949905 - I may be able to tell you if you can or cannot do what you want - I run one as true as --
Cheers Steve Driver
Old 07-31-2019, 06:28 PM   #10
Geo.T
Enjoy
Bratton's sells both 89" and 113" speedometer cables for AA trucks both keyed end and square end. This is what I used on the output end of my home-constructed Volvo overdrive.
George
Geo.T is offline   Reply With Quote
Old 07-31-2019, 07:16 PM   #11
Tom Endy
Tom Endy's Avatar
The colored Ford speedo gears described in the attached article are used in the Mitchell overdrive. They may be the same as used in the Volvo overdrive. They are apparently available from a Ford dealer.
Tom Endy
Tom Endy is offline   Reply With Quote
Old 08-05-2019, 09:14 PM   #12
NZ28ModelA
NZ28ModelA's Avatar
Originally Posted by Amyth View Post
Hi Steve
Cheers Steve Driver
Thanks Steve.. I will give you a call.. I still have to collect it from the engineer and fit it.
Kindest regards
Steve
Old 08-05-2019, 09:15 PM   #13
NZ28ModelA
NZ28ModelA's Avatar
Originally Posted by Gavin View Post
Steve,
Thank you Gavin.. It is [email protected]
This is much appreciated
Kindest regards
Steve
Old 08-05-2019, 09:17 PM   #14
NZ28ModelA
NZ28ModelA's Avatar
Thank you all for your help with this.. I would prefer to keep the speedo accurate if i can.
I appreciate all your input.
Kindest regards
Steve
