Old 07-22-2019, 08:55 AM   #1
DannL
DannL's Avatar
Default Jacking up car . . .
Are there any specific "preferred points" to place the car jack when lifting the Model A? So far I have lifted only under the middle front axle and under the middle differential. In both cases I was lifting two wheels off the ground. If I wanted to lift just one wheel off the ground at a time? Don't want to bend anything that's not already bent. ;-) Thanks in advance. Dann in OKC
DannL is offline   Reply With Quote
