#1 |
on my 1941 Merc.
whups, my starter is good (so far), I meant that my "push-button" switch, and how to get that dumb dirtyword switch out from my dash. stay safe. thanks |
#2 |
Assuming the Merc is the same as the Ford, it is held in place by prongs that are pushed in to release it.
#3 |
I believe it is orig (wish I still was), BUT, how the fug do I get it disconnected?? can't get my head to look under there because of the dirtyword clutch pedal knocking my head. stay safe. thanks
#4 |
Here are some photos of the switch. Not easy to get to,
#5 |
thanks... I NEEDED THAT !! u r correct, that dumb dirtyword thingy is definitely not easy to get to (except the front part)…. whups... looking at it, does that mean IF I push it from behind, that it will then POP OUT?? stay safe. thanks
#6 |
#7 |
There are 2 slots in the hole the switch goes in that lines it up so the "start" is at the top (or upside down if you put it in that way). I have always had good luck getting those out with a plastic tool to pry from the outside. Come in from one side (where the slot in the hole is) and it pushes one prong over. I haven't ever damaged paint on the dash and you don't have to be a contortionist to get your hand in there to try to squeeze those 2 prongs.
Remove one battery cable before you do this because it is easy to short the wire to the dash and engage the starter as you remove the switch. |
#8 |
Yes, a photo of the hole might help. This is a 1940 Ford, I have no idea if the 41 Merc is in the same orientation.
#9 |
thanks guys.... now have at least a concise idea of what I might be doing (ha). stay safe. thanks
#10 |
Based on your other post looks like this car is a 12v conversion. Depending on the style of starter solenoid you are using the starter button may be a two-wire vs the original on-wire. You might be able to tell by the appearance of the pushbutton. The original style should be metal and the two-wire are most often black plastic (the center button part). Not sure this is always the case, but it often is.
#11 |
BINGO. got it out... took a small screwdriver, filed the end down somewhat sharp, used a small hammer and got it under the lip of the button, and it popped out. THANKS. stay safe.
