Old 07-02-2019, 11:58 AM   #1
walkerlakeprinter
walkerlakeprinter's Avatar
Default Removing Bondo.
Is there anything out there that could soften Bondo (or whatever it is). I have 1/8" thick stuff on a very thin and rusty back window panel from my Special Coupe. Some of it pops off easily, but some is really stuck. I'm hoping to clean the piece off, use paint remover, and then sand it to prep for primer.
walkerlakeprinter is offline   Reply With Quote
Old 07-02-2019, 12:39 PM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: Removing Bondo.
While paint remover will attack plastic body fillers, try using a heat gun first to see if it will release.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 07-02-2019, 03:47 PM   #3
cuda
cuda's Avatar
I've used a silicon carbide disc on my grinder. I LOVE these things. Like this one:
https://www.lowes.com/pd/Gator-Power...isc/1000346965
cuda is offline   Reply With Quote
Old 07-02-2019, 11:54 PM   #4
Phil Brown
Phil Brown's Avatar
X2 on these, they work really good for removing old bondo but they do tend to polish the metal somewhat. Just make sure that the newly cleaned metal has enough surface teeth for the next step in your body work (epoxy primer or new bondo etc.)
Phil Brown is offline   Reply With Quote
Old 07-03-2019, 12:09 AM   #5
Chris Haynes
Chris Haynes's Avatar
Heat the bondo with a propane torch and it will fall off.
1921 Runabout
1930 Tudor
Early 1930 AA
Speed costs money. How fast do you want to go?
Chris Haynes is offline   Reply With Quote
Old 07-03-2019, 03:29 AM   #6
Oldbluoval
Oldbluoval's Avatar
Heat, gun back side if you can get to it
Oldbluoval is offline   Reply With Quote
Old 07-03-2019, 07:40 AM   #7
77Birdman
Never tried heat, I assume the heat gun wont warp the metal. I have used paint stripper, let it soak in for a bit and it comes off fairly easy. If its thick will take several coats. In the past I got the stripper from HD, got the best they had cant remember the name off hand.
77Birdman is offline   Reply With Quote
Old 07-03-2019, 07:44 AM   #8
Mulletwagon
Mulletwagon's Avatar
Propane torch is the way to go.
Mulletwagon is offline   Reply With Quote
Old 07-03-2019, 10:20 AM   #9
walkerlakeprinter
Thanks for all the ideas. After the Independence Holiday I will tackle all my projects. Learning as I go!
Old 07-03-2019, 03:17 PM   #10
whirnot
whirnot's Avatar
That looks similar to roloc discs. They work great and are quick change.
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
1931 Coupe
2 Smith Motor Compressors
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 07-03-2019, 06:01 PM   #11
BN
X3 on propane torch. Heat a small section (on the underside if accessible) just enough so that it peels off with a putty knife. Move to another section some distance away. Keep feeling the panel with your hand so it doesn't get too hot. This is what I did with zero panel warpage.
Bill Newland
BN is offline   Reply With Quote
Old 07-03-2019, 07:19 PM   #12
Oldbluoval
Oldbluoval's Avatar
I’d worry about warpage with a torch
Heat gun generally won’t get hot enough to warp
But experience and skill would preclude likely
Old 07-04-2019, 11:28 AM   #13
Kurt in NJ
Kurt in NJ's Avatar
Twisted knot stiff wire wheel on a grinder does good and won't bother good metal
