Old 06-22-2019, 02:48 PM   #1
mike42
mike42's Avatar
Default 1940 Starter
Took the '40 out for a run today and had a few stop to make. All was going well until I tried to start up after stopping at a store and there was nothing but a clicking sound. I have notice a couple times there was a whirling sound and then the starter kicked in. This time nothing except the clicking. After checking all the connections and I thought give it a shove and jumped in and put in second gear. I heard a clicking sound....turn on the key and it started right up. Would this be a bad Bendix or does it sound like a starter prob ? If just a Bendix...who would have the best one to buy to replace ?
Thx.....Mike
mike42 is offline   Reply With Quote
Old 06-22-2019, 03:24 PM   #2
19Fordy
19Fordy's Avatar
Default Re: 1940 Starter
First try by passing the starter solenoid and see if the starter is ok. Here's a view videos on how it's done.
https://www.google.com/search?q=how+...TF-8#kpvalbx=0
Old 06-22-2019, 05:56 PM   #3
mike42
mike42's Avatar
Ford ill give it a try in the morning.
Thx
Old 06-22-2019, 06:04 PM   #4
Andy
Sounds like a bad battery connection
Andy is offline   Reply With Quote
Old 06-22-2019, 06:18 PM   #5
petehoovie
petehoovie's Avatar
Make sure the starter motor mounting bolts a snugged up tight....
Old 06-22-2019, 06:44 PM   #6
TJ
TJ's Avatar
Definitely the first thing to check.
Old 06-22-2019, 08:32 PM   #7
deuce_roadster
deuce_roadster's Avatar
ALL electrical trouble shooting begins at the battery.
Old 06-23-2019, 03:49 AM   #8
mike42
mike42's Avatar
Cleaned the terminals and checked all connections. I jumper wired across the solenoid posts and starter kicked in right away. Battery is one year old RedTop Optima. Could the Bendix be not working properly ? I’ve never had a problem before and I’ve gone to the barn several times now an it cranks and starts right away ! Not a glitch !
Old 06-23-2019, 07:13 AM   #9
richard crow
if the sol. is bad. replace it with one that has the button on the bottom that you can push in
richard crow is offline   Reply With Quote
Old 06-23-2019, 07:14 AM   #10
19Fordy
19Fordy's Avatar
Drive it for a while so it reaches operating temperature. Then drive back into the barn , shut it off and see if it restarts.
Old 06-23-2019, 07:39 AM   #11
37 Cab
37 Cab's Avatar
Sounds like the Bendix was hung up on the flywheel.
Tommy
37 Cab is offline   Reply With Quote
Old 06-23-2019, 10:09 AM   #12
fortyfords
fortyfords's Avatar
Don't ever assume a battery is good just because its not very old. I've chased my tail over batteries that weren't very old and I assumed they had to be good. Your problem sure sounds like a bad connection or low voltage.
fortyfords is offline   Reply With Quote
Old 06-25-2019, 06:01 AM   #13
mike42
mike42's Avatar
I've started it a dozen times now and no probs !! For whatever reason I too think it hung up on flywheel and when I pushed it and put in 2nd gear it popped loose ! I did order a new Bendix from C & G and should have it Thursday. I'm going to replace it on my back-up starter and install. Is it better to leave it clean or light coating of 3 in 1 Oil ?
Thx.....Mike
Old 06-25-2019, 06:13 AM   #14
Terry,OH
Terry,OH's Avatar
No oil. Could use a little dry graphite lock lube.
Old 06-25-2019, 06:19 AM   #15
flatford8
flatford8's Avatar
A light coat of oil for storage can’t hurt. I think you fixed it when you cleaned the connections..... Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver…RIP
Old 06-25-2019, 08:08 AM   #16
19Fordy
19Fordy's Avatar
If the Bendix is still working, no need to replace it. Just carry a spare starter.
Old 06-25-2019, 08:31 AM   #17
Seth Swoboda
Seth Swoboda's Avatar
Thx.....Mike
I agree with your assessment. It was just hung up. It happens to me on occasion. I usually just put the car in 3rd gear and rock it back and forth to dislodge the bendix. Works every time.
Seth Swoboda is offline   Reply With Quote
Old 06-28-2019, 08:00 AM   #18
mike42
mike42's Avatar
Thx Guys....appreciate the advice. Bendix came yesterday and will put on my back up starter and leave things alone for now.
Thx again....Mike
Old 06-28-2019, 08:01 AM   #19
mike42
mike42's Avatar
Thx again....Mike
Old 06-28-2019, 09:16 AM   #20
mike42
mike42's Avatar
Well....just opened the package and I don't have to worry about doing any oiling of the new Bendix. It already has a good coat of grease and oil on it already !!
