Old 06-15-2019, 07:28 PM   #1
Mabel1930
Default Turning over but won’t start-slight electrical short
Hello all,
I’ve been in the garage all day with my ‘29 trying to figure this out; took a bumpy road the other day and the car shorted out. Came back to life but today shorted out again and now won’t start at all. All electrics work but when I turn the key on the pop-out, I show a 2-3 amp draw. Seems no power is getting to the coil as it shows no spark when on the starter. Anyone have experience with a similar problem or a bad coil? The current coil is only about 5 years old- all wiring is good and also checked the distributor bottom plate- all checks out. Could the coil have gone bad?
Thanks so much for any thoughts!
Mark
Mabel1930 is offline   Reply With Quote
Old 06-15-2019, 07:54 PM   #2
Mulletwagon
Mulletwagon's Avatar
Default Re: Turning over but won’t start-slight electrical short
Job #1 would be to put a volt meter on the coil studs to see if there is voltage there. Be warned many a good coil has been changed in a effort to solve an ignition problem. Should be able to trouble shoot fairly easily. A loose wire in the junction box or on the amp meter is an occasional problem. Pop-outs are sometimes problematic. They are designed to ground when off - maybe yours is remaining grounded when turned on. Good Luck.
Mulletwagon is offline   Reply With Quote
Old 06-15-2019, 08:08 PM   #3
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
Here is a video that should help you. The second half pertains to your problem. Search YouTube for “start that Model A 2019” and it should come up. Just because you hit that bump did not cause your coil, or any other part to go bad. Don’t change anything until you chase down the problem. Good luck.
Jacksonlll is offline   Reply With Quote
Old 06-15-2019, 08:08 PM   #4
Mabel1930
Is there a trick or anything I should specifically look for in repairing the pop-out or is it better to just replace it if found to be grounding out?
Old 06-15-2019, 08:19 PM   #5
GRutter
GRutter's Avatar
There's typically no such thing as a 'slight electrical short' - The 2 to 3 amp draw you are seeing sounds normal for your ignition coil. You are saying no spark when on the starter.. not sure exactly what you are doing. Assuming you mean no spark when trying to start. Troubleshoot the problem.. In my opinion if no spark look at distributor / point setting. Could be that the points are not opening enough to generate spark.
GRutter is offline   Reply With Quote
Old 06-15-2019, 08:29 PM   #6
Dick Steinkamp
Dick Steinkamp's Avatar
Can you elaborate on this statement? I'm not sure what you mean.
All steel from pedal to wheel
Dick Steinkamp is offline   Reply With Quote
Old 06-15-2019, 08:46 PM   #7
Tom Wesenberg
Tom Wesenberg's Avatar
Points may need to be cleaned or replaced. It happened to me when it lost spark while cranking with the starter. It fired right up with the hand crank though.
Old 06-15-2019, 11:23 PM   #8
Mabel1930
Seems to maybe be the pop out switch. I put a 1930 style armored cable on and bypassed the switch and the car fired up.
Old 06-16-2019, 08:54 AM   #9
Benson
Benson's Avatar
For those that might not know this:
If you had to loosen a head nut, even for a short time, to remove Popout be sure nut is tight.
Note:
In future always drain radiator before loosening that nut so coolant does not get into the oil pan.
Oil will be milky white after running if coolant got into oil!
Benson is offline   Reply With Quote
Old 06-17-2019, 04:34 PM   #10
Farrell In Vancouver
Farrell In Vancouver's Avatar
Maybe hot lead to ignition switch got loose behind the dash?
Farrell In Vancouver is offline   Reply With Quote
Old 06-18-2019, 02:28 PM   #11
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
31 people don't know what they're doing!!!!!
Bill W.
"THE ASSISTANT GURU OF STUFF"
