05-22-2010, 05:33 PM | #1 |
1929 Gas Tank
Hi Guys,
I have a nice clean fuel tank that I want to use in my resto but there's this problem.The choke rod bracket is off of it and all there is left is the 2 rivet mtg. holes in the tank. No problem coming up with another bracket but can it be attached with no rivets there? I'm also looking for a recommendation for a radiator shop in the S.NH / Mass border to do the work. Thanks, TG |
05-22-2010, 05:46 PM | #2 |
Re: 1929 Gas Tank
My guess is NO, a new bracket can not be put on and be expected to SAFELY hold gas the way it is now. HOWEVER, you can send it to Brent...he may have an idea or fix it for you.
Pluck |
05-23-2010, 01:49 PM | #3 |
Re: 1929 Gas Tank
Hi Tony, No reason you cannot re-rivet the bracket to the gas tank, but you will have to silver-solder it to be sure it won't leak. North Country Radiator in Queensbury, New York is not too far from you, and they can install an interior rubberized baked on coating inside the tank that will protect you from future leaks and corrosion. Good Luck!
05-23-2010, 02:17 PM | #4 |
Re: 1929 Gas Tank
I had a simular tank about 10 years ago. I was tempeted to to use#10 rivnuts and screws to attach a new one, but was not sure ow to get it all to seal back up without the use of the modern tank sealer. Also finfing a place to borrow the rivnut crimper may have been tricky. Rod
05-23-2010, 09:53 PM | #5 | |
Re: 1929 Gas Tank
Please tell us more about this rubberized coating and how the Ethanol will/will not affect it. |
05-24-2010, 11:24 AM | #6 |
Re: 1929 Gas Tank
05-24-2010, 01:52 PM | #7 |
Re: 1929 Gas Tank
Looks like it's Gas Tank RENU. (site here: http://www.gastankrenu.com/) but I'm still wondering how well an applied coating will stand up to ethanol.
Anybody have any experience with this stuff in the longer term? |
05-24-2010, 06:16 PM | #8 | |
Re: 1929 Gas Tank
05-24-2010, 11:17 PM | #9 | |
Re: 1929 Gas Tank
I think you're right though--GTR isn't advertised as baked, so what they did to your tank could have been something else (better). It does seem like there should be some solution that will hold up. After all, a lot of tanks are plastic these days. |
05-25-2010, 08:14 AM | #10 | |
Re: 1929 Gas Tank
