Old 05-17-2019, 10:38 PM   #1
31Abone
31Abone's Avatar
Default 1934 21 stud need info oil presure +leaks
I have worked on model A and B motors,shims ,oil slinger etc.. before i pull motor ..oil presure about 30 when cold but about 5 to 10 psi when hot...no smoke out of pipe but leaks oil when shut down..does 1934 21 stud have floating rod bearings like a 59AB ? can I shin rods and mains to tighten clearence like a model B ??? compression about 65 to 75 each cylinder.. runs good and good power.... but I think I will have to pull motor..opinions needed ..thanks in advance..
31Abone is offline   Reply With Quote
Old 05-17-2019, 10:44 PM   #2
Tinker
Tinker's Avatar
Default Re: 1934 21 stud need info oil presure +leaks
34 is babbitt mains. So there could be shims to remove.
To me the oil pressure doesn't sound bad, 0 is bad, pretty normalish on a regular old engine. We tend to over do things. But It wouldn't effect cylinder pressure, which is a bit low.
You could remove the pan and clean the pickup screen and/or at the same time change out the oil pump spring. Off hand I wouldn't be to worried about the oil pressure.
They all leak a little oil. or not... depends on whom you ask. If power is good, run it.
Old 05-17-2019, 10:59 PM   #3
flatjack9
flatjack9's Avatar
The engine does have floating rod bearings.
Old 05-17-2019, 11:47 PM   #4
Kurt in NJ
Kurt in NJ's Avatar
it should not have shims
Old 05-18-2019, 07:43 AM   #5
jimTN
Shims on the mains and no shims on the rods.
jimTN is offline   Reply With Quote
Old 05-18-2019, 08:40 AM   #6
34billct
34billct's Avatar
V8's Never had shims.!
34billct is offline   Reply With Quote
Old 05-18-2019, 10:26 AM   #7
JM 35 Sedan
JM 35 Sedan's Avatar
Probably not from the factory, but I had a '35 21 stud flathead V8 engine rebuilt by Schwalms in Strasburg, Pa., and he used shims on the mains. I found them in place when I had to remove the oil pan for an unrelated problem.
This engine now has over 35k miles since rebuild, so I see no problems related to these shims.
John
