Old 04-23-2019, 01:39 PM   #1
Geo.T
Default Restoring crank and rod bearings
In the past I recollect restorers using two kinds of powder (one course and the other finer for finishing) which when mixed with oil were used to restore bearing journals. Prussian Blue was used to measure progress. One of the powders was color yellow. Apparently the abrasive qualities deteriorated to zero with use so that clean-up was not a big concern.The reports were very positive. I am unable to find info in the archives. Does anybody have further info, advice, including source for obtaining?
Thank you in advance. George
Geo.T is offline   Reply With Quote
Old 04-23-2019, 02:22 PM   #2
Bob C
Default Re: Restoring crank and rod bearings
Timesaver https://www.ws2coating.com/timesaverlappingcompounds/
Old 04-23-2019, 08:53 PM   #3
RUNNERBUN
RUNNERBUN's Avatar
Snyder's sell the Timesaver.
Adjust your points with gentle blows of a 2 pound hammer
RUNNERBUN is offline   Reply With Quote
Old 04-23-2019, 10:51 PM   #4
ursus
Timesaver for babbitt and soft metals like bronze or brass comes in three grades of abrasiveness. Follow the directions regarding the relative amounts of Timesaver and oil in the mixture and do not exceed the percentage of Timesaver advised. You should only need the fine grade although a rough fit might require the medium grade. Take your time and do it right!
ursus is offline   Reply With Quote
Old 04-23-2019, 11:01 PM   #5
PC/SR
Be careful that none on the rear bearing seeps out the ends onto the thrust faces. Will throw off the crank end play. Cover the thrust faces with scotch or other tape if there is room. Watch the end play and measure as you proceed.
Edit: Friend says I am too negative. I do like timesaver, just watch the crank end play. Should not be a problem unless you do a lot of lapping with coarse or medium grade, but again, pay attention to end play.
PC/SR is offline   Reply With Quote
