Old 04-19-2019, 10:04 AM   #1
tommyleea
Default 53 Ranchwagon master cylinder
Original master cylinder removed. The pushrod is still in the master cylinder. I don't see anywhere that says the pushrod is part of the master cylinder, however, it is not coming out of the master cylinder easily. I assume it is just rusted in, and no disassembly is required to remove it. Should the pushrod just pull out of the master cylinder? Thanks
tommyleea is offline   Reply With Quote
Old 04-19-2019, 11:24 AM   #2
TJ
TJ's Avatar
Default Re: 53 Ranchwagon master cylinder
It should just pull out.
Old 04-19-2019, 12:34 PM   #3
Merc Cruzer
Merc Cruzer's Avatar
Does it have Power Brakes?
Merc Cruzer is offline   Reply With Quote
Old 04-19-2019, 09:22 PM   #4
paul2748
paul2748's Avatar
Some Ford push rods around that time had a plastic tip that went on the end of the push rod to hold the rod into the master. The push rod should just pull out, but over the years may be rusted which makes it harder to pull out.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 04-19-2019, 09:24 PM   #5
paul2748
paul2748's Avatar
Based on my experience with 54-56 brakes, shouldn't make a difference as the master for power and non power brakes was the same because of the remote booster.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 04-20-2019, 08:06 AM   #6
tommyleea
Great, Thanks for the info. The rod finally did come out, and there is a plastic tip on the end. Also, about midway on the push rod is a collar. The collar will spin, but it doesn't adjust anything. Also looks like there might be a rubber seal on one end of the collar. The seal is rock hard now. Any info about this collar/seal that is on the push rod? The collar will spin, but it doesn't move up and down along the push rod. Thanks...No power brakes..
Old 04-20-2019, 09:17 AM   #7
TJ
TJ's Avatar
The master cylinder does have a rubber boot that fits over the rod and also covers the end of the master cylinder. The boot has probably deteriorated and all that is left is part of the boot on the rod.
Old 04-20-2019, 09:31 AM   #8
Merc Cruzer
I asked if you had power brakes so I would know what to post. Hope these help.
Old 04-20-2019, 03:10 PM   #9
tommyleea
No power brakes...Thanks for the pics.
Old 04-20-2019, 03:12 PM   #10
tommyleea
After further review along with pictures from Merc Cruzer, I believe you are correct, and it is just left over rubber boot. Cheers
