Old 04-16-2019, 08:51 PM   #1
RalphG
RalphG's Avatar
Default Found Some Brake Drums and More
This old trailer has sat in the bush for decades on my grandfather's farm. Only today I noticed that it is built on the chassis of an old Ford. Appears to be between a 40 and 48 judging by the hyd brakes, no wide fives, and torque tube differential. I wonder if those drums fit my 39 Deluxe? Will have to check the catalogue.
RalphG is offline   Reply With Quote
Old 04-16-2019, 09:00 PM   #2
Tinker
Tinker's Avatar
Default Re: Found Some Brake Drums and More
Lots of salvageable parts just in those two pictures. Sometimes the little stuff like the spring ubolts are nice to have.
Old 04-16-2019, 11:44 PM   #3
deuce lover
deuce lover's Avatar
They will fit.I did that same thing back in 1963.
deuce lover is offline   Reply With Quote
Old 04-17-2019, 10:44 PM   #4
Flathead Fever
Flathead Fever's Avatar
Why is there a chain around the left axle housing? If its an anti theft device I'm thinking that being buried in the ground should be good enough to keep it from walking off.
Flathead Fever is offline   Reply With Quote
Old 04-17-2019, 11:12 PM   #5
RalphG
RalphG's Avatar
It appears that small chain reached up to the ball joint of the front wishbone. I need to do a little more digging to get a better look under the rotting wooden wagon box and see what all Ford parts are there. Good to know the drums will fit my 39.
Old 04-18-2019, 09:36 AM   #6
cas3
the drums will fit your 39 if you wish to change to the later wheels.
