04-15-2019, 08:46 AM | #1 |
Fan Movement
After removing my alternator and belt removed, when I grab the fan blade, I can slightly wobble the entire fan assy. Is this a potential disaster in the making or is a little play normal? Thanks.
If it aint broke, don't fix it! |
04-15-2019, 08:49 AM | #2 |
Re: Fan Movement
Normal water pump with 2 blade fan. as original style?
www.whidbeymodelaclub.com |
04-15-2019, 08:58 AM | #3 |
Re: Fan Movement
Vince Falter at his most excellent FordGarage site references problems with reproduction water pump shafts including: wrong taper, TWO tapers, taper stick through before nut fully clinches fan.
ALSO issues with the fan hubs including female similar to above. See http://www.fordgarage.com/pages/waterpumpshafts.htm Early repro two blade cast aluminum fans are noted to issues in the hobby as the fan was die cast aluminum, but the tapered shaft hole not machined or machined incorrectly. New cast fan blades have this problem solved. Some have gotten past the issues by putting an additional washer under the fan and torquing the heck out of it. Maybe not so much solving the issue as "getting past." Some check out seems in order... Joe K
Shudda kept the horse. |
04-15-2019, 10:06 AM | #4 |
Re: Fan Movement
To answer your question directly, the fan should NOT wobble at all.
04-15-2019, 10:21 AM | #5 |
Re: Fan Movement
Original blade or the new aluminum blade?? Either one should NOT wobble.
Paul in CT |
04-15-2019, 11:24 AM | #6 |
Re: Fan Movement
04-15-2019, 02:25 PM | #7 |
Re: Fan Movement
It has the 4 Blade version. Looks like something else I wil need to remove and examine.
04-15-2019, 03:03 PM | #8 |
Re: Fan Movement
The Four blades like to crack at the rivets. To be clear do you mean wobble
or fore and aft movement (end play)? Bob |
04-15-2019, 04:28 PM | #9 |
Re: Fan Movement
Wobble. When I grab the fan blade with one hand and the the pulley with the other, they wobble in unison...the water pump shaft doesn't. This is withthe belt very loose (alternator was removed). The nut and cotter pin are intact.
04-15-2019, 09:53 PM | #10 |
Re: Fan Movement
You are talking a wobble on the shaft, not the entire assembly moving in and out?
04-16-2019, 08:29 AM | #11 |
Re: Fan Movement
Yes sir-wobble on the shaft. The shaft is intact in does not move.
04-16-2019, 10:41 PM | #12 |
Re: Fan Movement
It sure sounds like the nut didn’t or won’t tighten, and for some reason the shaft tapers are damaged. You may get by with a new fan, but very possibly a new pump shaft as well.
04-17-2019, 04:50 AM | #13 |
Re: Fan Movement
I removed the pin and tried snugging the castle nut-no dice! It was not getting any tighter. On to removing the water pump and will try to replace the fan first and see if that will work. Hopefully the radiator will lean forward enough for clearance but if it doesn’t no problem-will just remove it.
04-17-2019, 07:57 AM | #14 |
Re: Fan Movement
On the last fan I replaced for a friend the hub in the pulley was split. This was on a 4 blade fan and it barely scared the radiator. I have another friend with a 4 blade fan that is hitting the radiator and I have a new pump, 2 blade fan, hoses, belt,and fake studs ready to change out when time allows.
Terry O |
04-17-2019, 11:45 AM | #15 |
Re: Fan Movement
I ordered a 2 blade fan from Snyder's and will switching out my 4 Blade. If I am fortunate, there will be no damage to the shaft and the new fan will snug-in nice and tight. Since I have engine pans installed, I will need to attach a rubber hose to the petcock valve and route it past the pan. Not looking forward to removing the radiator but that's how it goes sometimes.
