#1 |
What is the proper way to pump grease through Model A grease fittings ? Are there any direct conversion zerk-type fittings ? If so, are they worth converting to ?
#2 |
You just push the gun on the end of the fitting and pump, but you need to have the proper end on the gun. The parts suppliers should all have them.
You can buy a kit with all the modern zerks in it. Some are driven in and some are threaded, so you would need to get the driver and a list of which are which. Most all the jobs we do are drivers so install modern zerks.
I know the voices aren't real but damn they have some good ideas! ![]() |
#3 |
jacking may make the spindles easier to grease. I use a air gun.
#4 |
The original type were Alemite, todays standard are Lincoln design. This is the gun fitting that Bratton's sells for the original Alemite fittings.
https://www.brattons.com/grease-gun-adapter.html |
#5 | |
![]() Quote:
#6 |
Bill Worden 1929 Roadster 1929 Briggs Town Sedan 1930 Closed Cab pickup 1931 Coupe 2 Smith Motor Compressors 1951 Ford F1 High Desert Model A's |
