Old 03-19-2019, 08:40 PM   #1
v8fordman
v8fordman's Avatar
Default Remote door handle spring install
Does anyone know of a special "trick" for installing the spring on the remote (handle) end of a door latch assembly? I was wondering if it can be done without heating the tabs and removing the mechanism cover. I'm working on a '37 pickup.
v8fordman is offline   Reply With Quote
Old 03-19-2019, 09:01 PM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: Remote door handle spring install
I have done it without heating.
Using a sharp chisel to start opening the tabs then a larger screw-driver like device to further open until able to grasp with vice grips to fully straighten.
If any tabs break off a simple tack weld will secure the plate to the body.
