Old 03-18-2019, 06:59 PM   #1
russcc
Default Sticky throtttle shaft
Need some ideas. After sitting for a few months the carb throttle shaft on the '40 was stuck. I believe it was one that Charlie rebuilt, so we know it's good. Any ideas on how to keep loosened up. Thank you Fordbarners.
russcc is offline   Reply With Quote
Old 03-18-2019, 07:28 PM   #2
JSeery
JSeery's Avatar
Default Re: Sticky throtttle shaft
Carb cleaner?
Old 03-18-2019, 07:35 PM   #3
drolston
drolston's Avatar
Fair chance it is the throttle plate stuck in the bore, rather than the shaft itself. Shoot some WD40 down the bores and on both external shaft ends. If the carb is a 97, shoot a little of that WD40 into the accelerator pump on top of the carb.
Old 03-19-2019, 05:18 PM   #4
russcc
Ingot it loose, and it does not like the throttle plates as it was sticky all the way to wide open. Any recommended preventative measures ? Thank you Fordbarners.
Old 03-19-2019, 06:18 PM   #5
Charlie ny
If you can live without the carb for a week send it back, please include return
postage, I'll figure it out N/C.
Charlie ny
Charles Schwendler
5845 Cole Rd.
Orchard Park, N.Y.
14127
Charlie ny is offline   Reply With Quote
Old 03-19-2019, 06:49 PM   #6
Brian
Brian's Avatar
Yet another example of Charlie's impeccable work ethos..
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
