Old 03-18-2019, 03:12 PM   #1
chrs1961815
chrs1961815's Avatar
Default Choke Rod Just Spins
When trying to adjust the mixture, my choke rod just turns and doesn't stop, not making a difference in the way it runs. The choke rod is original and the carburetor was just rebuilt. What's wrong?
chrs1961815 is offline   Reply With Quote
Old 03-18-2019, 03:35 PM   #2
Russ/40
Russ/40's Avatar
Default Re: Choke Rod Just Spins
Pull the needle and housing from the carb. Your needle has likely broken at the connection to the choke rod.
Russ/40 is offline   Reply With Quote
Old 03-18-2019, 03:47 PM   #3
chrs1961815
Thank you. That would make sense as it used to work.
